Results 11 to 16 of 16
    Jan 2011
    Markham, Ontario Canada
    Right from my 2010 1500s owners manual 140ft/lbs
    You are good with 120-140ftlbs on the wheels and for the drain plug i just go snug plus a little more. as for using Air tools on wheels you can use them on alloy wheels or steel and if done correctly with the proper sockets and torque sticks you should have no problem removing the lug nuts with hand tools. I do it on my truck at the shop all the time and have no problem removing them with a breaker bar or a longer 1/2in ratchet
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Mar 2013
    adirondacks,n.y.
    our biggest problem is service managers were never wrench turners,just quick on the keyboard to keep the money flowing!i owned a garage for quite a while and fixed many a problem from them,i.e. retorqeing wheels to clear up warped rotors,thank god for the help rack for oversized drain plugs,they have the diagnostic ability with g.m.,ill leave it at that!
    drain plugs shpuld never be put on with an impact! i have done wheel lug nuts with a impact to take them off, then back on, but i use the lowest air settting just to get them started, then i get the torque qrench out and torque to 135....
    never had an issue.
    Alex
    alright for all the Impact haters out their this is what i use(not same brand) I have never had a problem with wheels coming off or being overly tight, i have even checked them against a torque wrench and have always been withing 2-3 ftlbs using the highest setting on my impact
    http://www.tooltopia.com/genius-tool-to405ext.aspx
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Quote Originally Posted by nickgiacalone View Post
    I third the 120 ft/lb of torque on the lug nuts for a 1500. The specs on my last truck (2500HD) was 140 ft/ lb
    I guess that I will be torquing them to 120 from now on.
  1. Radiator drain plug
    Last Post: 05-05-2011, 03:20 PM
  2. Transmission Pan Drain Plug Kit
    By BustedKnuckles in forum GM Powertrain
    Last Post: 01-26-2011, 02:38 PM
  3. Oil drain plug thread size?
    By GlitchMobile in forum General Chevy & GM Tech Questions
    Last Post: 01-22-2010, 06:51 PM
  4. Mystery of the bearings at the oil drain plug
    By peteroli in forum Chevy C/K Truck Forum
    Last Post: 04-12-2009, 12:25 AM
  5. Butterfly Drain plug
    By uscs04 in forum General Chevy & GM Tech Questions
    Last Post: 11-05-2008, 12:37 PM
