    Default New master cylinder???
    I got to replace the master cylinder in my 02 Silverado 8.1liter 2500hd. Can anyone link me to a new one ya'll recommend or any advice in general? I should have photos posted tomorrow to show yall where it is leaking. I have already tried using Lucas oil to swell the seals and stop the leaks.
    LB7|2" lift|20" rockstar xd's|wrangler mud tires|Leer cap|4in turboback|volant CIA|boost increase valve|EFI by DTS|phantom gauges|6 speed ZF-6|solid mass flywheel|ceramic Kevlar clutch|High idle switch|55 gallon in bed fueltank|Edge insight|4 rigid dually|app radio 2|250watt kicker amp an 10" sub
    I bought two ac delco units new from the dealer, one was made missing a seal, and the second one was improperly manufactured. I ended up getting a cheap one from rock auto for $68.00 complete, been going good for a year now.....
    i have had good luck with the Napa line of master cylinders
    http://www.napaonline.com/Catalog/Re...+5999999+26355
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Are you sure it's the master cylinder leaking and not just the reservoir?
    Mine turned out to be just the reservoir, found an ACDelco on Amazon for $35.00 shipped, way less than the $130 the dealer wanted!
    Opiewho
    2004 Silverado 2500HD W/T
    6.0L, RWD, Auto w/Towing Package
    One more thing I should add, make sure you bench bleed the new unit before you put it on the truck.
    x2 on that. I have also had the same experience with some AC delco parts from the dealer. Not made correctly or missing parts. AC delco has now started remaning parts like Power steering pumps. They, like everyone else, lack quality control during the rebuild process.
    Turns out it was just a few hoses and claps. Easy fix.
  1. Are master cylinder the same
    By WesBrown82sub in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 04-23-2012, 08:22 AM
  2. Master brake cylinder
    By ratbag in forum General Chevy & GM Tech Questions
    Last: 11-17-2010, 02:17 PM
  3. master cylinder wire????
    By kylegillean in forum General Chevy & GM Tech Questions
    Last: 07-20-2009, 12:24 PM
  4. New master cylinder or rebuild kit
    By ACracing in forum General Chevy & GM Tech Questions
    Last: 06-22-2009, 08:32 AM
  5. Master Cylinder is it Bad?
    By ceyermann in forum Lifted & Offroad Suspension
    Last: 08-13-2007, 06:30 PM
