    Default Rear Disc brake kit
    Has anyone swapped out the rear drums for disc on their truck?
    was it front ABS only?
    how easy was it? how do you like it?
    im looking at a kit, please let me know.
    thanks! =)
    I'll tell you what happened to me, and let you make a judgement.
    2004 Chevy Colorado 2wd disc front brakes, drum rear brakes. Rear disc conversion kit was $1,100 for my truck. I couldn't justify that much for brakes, so I found a better solution. Swapped the whole rear axle from a Trailblazer SS, 12" rotors 4 piston calipers, 4.10 gears, LSD $500 cash money at the junkyard.
    I got multiple upgrades in the same boat, as far as ABS I deleted the whole original setup. Went to all braided stainless lines, added a line lock, proportioning valve and she was good to go. I have around $1,000 in the whole setup, less then what they wanted for my disc brake conversion kit.....
    What was your original gear ratio? How do you spec what proportioning valve to get?
    Just curious but why did you swap out your drum brakes for disc? I've a 2009 serria 1500 and would like to do the same (as in junk yard swap) but wonder if it is really work it. Am changing out the front with Willwood disc & calipers, like the look and I know disc are lighter but need a better reason than it looks better.
    @Headroom My original gear ratio was 3.42, I need to get my truck retuned as the speedometer is off by about 15mph.
    @nikkeshelton- the real reason I did the swap was for the 4.10 gears, better splined axles, and a locker for a two wheel burnout. The disc brakes were welcomed as this also accompanied a V8 swap
    As far as proportioning valves, I still don't honestly understand them lol!! I went to Summit Racing, told them my setup and they sold me the one I have and it works great.
    cool!!
    i was thinking about getting a junk yard axle as well, especially if i could get a 12 of 14 bolt...... but i just paid over $1,000 because my factory 10 bolt blew out on a road trip X(... so yeah... would be difficult to sell a brand new 10bolt posi that got used... i was stranded and needed it.
    it would just be a pain to hunt for the correct gears and a good posi unit in a simmilar high millage truck... but it may be worth it... not sure if i would need a different proportioning valve though. the one now tracks very straight in a panic stop
    i think deleting the ABS is easier on OBD 2 vehicles... when i disable mine the whole computer freaks out, throws check engine lights, and the speedo does not work...
    I can't speak as far as the idiot lights and stuff, because we are running an IPAD for a gauge cluster but I'm sure there would be all kinds of lights on lol!!! As far as the speedometer not working, that is a weird problem....
    indeed so.....
    guess i just need to stick to the limit of stock, unless i want to rewire the whole vehicle.... which would SUCK to do and pass emissions... CA sucks Xp
  1. 1997 rear disc brake conversion?
    By chevyman1297 in forum Lifted & Offroad Suspension
    Last: 10-24-2011, 08:56 AM
  2. Affordable rear disc brake kit for 88-98 1/2 tons?
    By Blacksheep1 in forum Lifted & Offroad Suspension
    Last: 03-29-2011, 12:36 PM
  3. rear disc brake conversion
    By yogibear in forum Lifted & Offroad Suspension
    Last: 08-27-2009, 06:57 AM
  4. rear disc brake conversion
    By yogibear in forum Performance & Fuel
    Last: 08-25-2009, 02:10 AM
  5. 98 sub rear disc brake upgrade
    By sho in forum Lifted & Offroad Suspension
    Last: 12-08-2008, 11:54 PM
