Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    I wish I could get ethanol free but I live in the great state of Commiefornia (ok there are like 4 stations but they are 600+ miles north of my location).
    I also use TC-W3 like @blackburb and 87 octane
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  2. #22
    Quote Originally Posted by dsfloyd View Post
    TC-W3 is a specification for 2-cycle oil. The engine in my truck is a 4 stroke engine not requiring oil to be mixed with the gas. This sounds absolutely preposterous to use 2 cycle oil in a 4 stroke engine.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
  3. #23
    I agree with you! I was also pretty skeptical about it. I started running it with a 1 ounce to 5 gallon ratio 3 tanks ago. My idle has smoothed out significantly. It was enough that my wife asked what I had done to the truck because she always commented on the rough idle. I drive the same routes and fill up at the same gas station every time. I have noticed an increase in my city mpg from 16.6mpg to 17.5 mpg over the last 3 tanks. I am sure that some other factors contributed to this like wind and temperature. So far it has worked for me. My truck has 150,000 miles on it and had 136,000 when I bought it. I always hated the way it idled. As of now I am happy with the results. If something changes I will be sure to let everyone know.
  4. #24
    you do it at a 1 oz per 5gallon mix so not like its a 20:1 ratio (its actually a 640:1 ratio). So its a small amount and adds detergents to the gas. Been using it for a few years now, pulled my injectors a little while back when I had to replace something and they were nice and clean at close to 100k miles (at that time). Its also a premium ashless marine formula (the tc-w3 not just any 2 stroke oil). But as with any additive, detergent etc, could it all be snake oil? Sure it could.
    David
    NRA Life Member
  5. #25
    I was unaware that 2-cycle oil contained detergents. If 2 cycle oil does contain detergents, then it probably cleaned out @Pikey and @dsfloyd fuel injectors. Would not Lucas fuel treatment have done the same thing?
    Mods:
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
  6. #26
    I am not super well versed on the subject. But, I do not think that the lucas has lubricating properties like the Tc-w3 does. Again, I could be wrong. All I know is that I have run seafoam, lucas, and multiple other "fuel system cleaners" thru my tank and never had results like I have this time. I am happy to see a little added mpg, I am most happy about the smooth idle.
  7. #27
    @Pikey, I'm sitting here shaking my head, but I'm going to try it. I have a little hang on my throttle, I lift my foot to come to a stop and the drive by wire won't let the rpms drop off like they use to, I'm thinking a dirty throttle body and I was going to pull it and clean it. This might be a good test.
  8. #28
    Yes lucas would do it to, but when a 1 gallon bottle of TC-W3 can be had for $15-20 and you use 3-4 ounces a fill its much cheaper.
    Also you want to make sure that it is the TC-W3 marine and not just standard 2 stroke oil
    David
    NRA Life Member
  9. #29
    Jr. Mechanic blackburb's Avatar
    Nov 2008
    In Da U.P. of MI - - M Go Blue!
    Ding, ding, ding. We have a winner. Actually several. As I mentioned earlier, the 2-stroke oil additive is much, much cheaper than "specialty" additives. As far as data, you need to go back to the LS1 forum link I gave before. A substantial amount of real world testing has been done on this, and the results are always positive. Maybe a little boost in mpg, but always cleaner plugs, injectors and entire fuel system. Those guys are certified car nuts who put the time and effort into trying numerous different products in their personal vehicles over quite a long time. They have no vested interest and no monetary gain from endorsing the product they found to work. I will believe them and their results (which I'm glad to see members here are confirming) over the marketing drivel that's slapped on the bottles that sit on store shelves.
    '01 K2500 496 big block It's here! It's here! It's finally here!
  10. #30
    The throttle body will not be cleaned with this method, just injectors.
  1. Up grade ideas
    By DamnThatMexican in forum Chevy C/K Truck Forum
    Last Post: 03-29-2013, 04:18 PM
  2. 2002 GMC 2500 up grade.
    By RAV52202 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-16-2013, 10:39 PM
  3. Mirror up grade
    By nikkeshelton in forum General Chevy & GM Tech Questions
    Last Post: 10-16-2012, 04:16 PM
  4. Grade 8 studs
    By TWODOGS in forum The Coffee Shop ~ Chit Chat
    Last Post: 01-26-2010, 01:53 PM
  5. up grade my stero
    By Bens Dad in forum Audio, Video & Gadget Tech
    Last Post: 03-23-2009, 06:48 AM
