    Default 2008 envoy front end rebuild, any advice??
    In the morning I an changing out both lower control arms, both upper ball joints, front and rear sway bar links, and rear upper and lower trailing arms. I have rented a ball joint press to do the uppers. Any suggestions or tips that you think I might need? Thanks
    Air chisel, cutoff wheel, spray the whole area with PBS blaster and let soak lol!!!
    Well, I got it done. It took about 10 hours total. (took 5 hours for the driverside front, I waited 2 hours for parts) I ended up changing the upper and lower control arms and upper ball joints on each side. The Front swaybar links and bushings. The rear upper and lower trailing arms on both sides, rear swaybar links and bushings. It went pretty well. Except for 3 things. To get the lower control arm off I had to remove the CV shaft nut and push the shaft back, (no room to slide ball joint out) that would have been easy, if I had the correct socket. So, my boss spent 2 hours driving around (in my truck) getting the socket and the upper control arms that he decided to replace after I had started. Another issue was the new lower control arm brackets had too much flash on the casting at the holes and the bolts would not fit, so I had to grind the flash off. Not a big deal, except that I did not realize it until I had already wedged the bracket into the frame slots, then had to remove it. The other issue was the rear sway bar links. I ended having to cut 3 of the four ends off due to corrosion. I started with a saws all, those suckers were hard, so I ended up cutting them with a cutoff wheel on a die grinder. I would say that it went pretty well. I guess that I am now prepared for when he decides to do the same to his wife's envoy.
  1. Just purchased a 2008 Envoy SLE2, wondering
    By hockster31 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 11-20-2011, 10:56 PM
  2. new front shocks advice...
    By reggiecab2000 in forum Lifted & Offroad Suspension
    Last: 07-05-2011, 04:31 PM
  3. 2005 2006 2007 2008 2009 envoy keyless entry remote fob
    By ChevyFan in forum Chevy Keyless Entry Remotes
    Last: 05-27-2011, 03:40 PM
  4. Front bumper damage on 2008 silverado. Advice needed
    By image0r in forum General Chevy & GM Tech Questions
    Last: 03-16-2011, 04:38 PM
  5. Front differential rebuild help
    By Boiler74 in forum GM Powertrain
    Last: 03-16-2008, 09:39 AM
