Results 1 to 9 of 9
    Default 95 chevy K1500 - Squeaks bad when go over bumps
    I have a bad squeak when I turn my wheels and while I'm driving how can I fix this problem?
    Welcome to the G M T C !
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Welcome to the club, it's great to have you aboard. We need more info on your vehicle and the squeak so we can help.
    It's a 95 ext cab K1500 z71 and I have a really bad squeak when I turn my wheels or driving down the road if I hit any little bump it squeaks I had someone tell me my rubber bearings were dry and that could be the problem. It sounds like its by my shocks
    From the information that you gave it could be almost anything! there are too many things there to say that it sounds like it is the shocks. A sway bar link is right there, along with wheel bearings and a cv shaft. I would start by looking at shock bushings. It could be swaybar links, sway bar bushings, a wheel bearing, cv shaft issues, front diff issues, front ujoints, the list can go on. I would need a little more info. does it do it when just rolling straight on a flat surface(no bumps)? Does it do it more or less in 4x4? Is it louder when turning in one direction rather than the other? If you bounce on the front bumper does it make the noise? If so have a friend start bouncing the front end, get under there and try to locate where your squeak is originating. Posting a video of the sound may help also.
    Yes it makes noise when someone is jumping on the bumper and also when I turn to the right I think it could be the control arm and maybe the ball bearings
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Welcome to the Club!!
    ***Moved thread to correct section***
    TIRES:
    BFG All Terrain KO 315/70/17
    Your squeek could be any of the rubber bushings, another posinility is dirt and debris between the leaf springs.
    Welcome! It could well be a combination of what tbplus10 mentioned...
  1. Front Driver Sides Squeaks like a Son of ..........
    By Whiterado in forum Lifted & Offroad Suspension
    Last: 06-07-2011, 03:22 PM
  2. 2007 Silverado Squeaks!
    By drillbit26 in forum General Chevy & GM Tech Questions
    Last: 02-06-2011, 10:12 AM
  3. Squeaks and Cracks and noise
    By ippielb in forum General Chevy & GM Tech Questions
    Last: 07-24-2010, 10:07 PM
  4. squeaks and chirps. what is it?????
    By 01chivyz71 in forum General Chevy & GM Tech Questions
    Last: 09-19-2009, 01:01 PM
  5. Squeaks and bad idle
    By Silverstreak in forum General Chevy & GM Tech Questions
    Last: 06-19-2009, 04:03 PM
