    Default Steering issues only can turn left
    Just bought me a 85 k10 half ton with 10" lift 37s and 22s and 89k original miles on it clean as clean can be but had steering all torn apart when i got and i bought the drop bar for the steering and then had to buy a 3" spacer also so that the linkage from the steering box wasnt on such a bind and got that all in yesterday and can't turn right still idk if the newer steerin column wasnt put on correctly or if the power steering pump is messed up?
    Welcome to the club, it's great to have you aboard. I am unable to help you with your problem but someone here will be able to help.
    maybe the gear box was not centered when you hooked it all up. It may have been all the way right already when you installed everything.
    Yea i thought that too i never stuck the column in the truck but thats what made sense to me too just thought id get a second opinion, does anyone know where u can buy led tailights for my 85?
    I would start a new thread for the tail light question
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Welcome to the Club!!!
    ****Thread moved to correct section****
    TIRES:
    BFG All Terrain KO 315/70/17
    Welcome!
    Any luck?
  1. 2004 chevy suburban turns left fine but to turn right is like manual steering
    By TMair in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 04-22-2012, 05:16 PM
  2. Noise when I turn left or right.....
    By DSpivey in forum Lifted & Offroad Suspension
    Last: 09-09-2010, 09:20 PM
  3. Help!!! Hard left turn
    By disturbedvn in forum GM Powertrain
    Last: 07-29-2010, 05:41 PM
  4. Turn Signals Out on Left SIde Only
    By gotprops in forum Audio, Video & Gadget Tech
    Last: 05-22-2009, 02:24 PM
  5. fast left turn signal
    By aftriathlete in forum Audio, Video & Gadget Tech
    Last: 02-10-2009, 07:33 PM
