    Jr. Apprentice Arbitert343GS's Avatar
    Oct 2010
    Lawrenceville, Ga
    Default Engine not starting
    I have a 1999 Chevy C1500 with a 5.7 and I recently swapped frames(the only thing done to the engine was it being pulled, I did no other work on it), well I hook everything back up(used wiring diagrams to double check) and now its giving off an intermittent spark from the coil. And will not start at all. Any ideas?
    Brandon - Georgia
    1999 Chevy C1500
    1978 Pontiac Trans Am
    Either a bad coil, bad positive connection, or bad ground.
    Double check your connections, I suspect the coils good but you either have a loose ground or you might have internally damaged a wire during assembly.
    Oct 2010
    Lawrenceville, Ga
    Thank you for the help! It ended up being condensation in my distributor. I got it running earlier after I let it dry out.
  1. Strange noise after starting the engine
    By rwmoorh in forum General Chevy & GM Tech Questions
    Last: 07-08-2010, 12:05 PM
  2. 96 K1500 hard starting when engine cold
    By kcstrom in forum General Chevy & GM Tech Questions
    Last: 08-25-2009, 08:54 PM
  3. Security system/engine not starting
    By Trask215 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-25-2009, 09:08 PM
  4. Engine dies after starting
    Last: 12-07-2008, 11:41 AM
  5. Truck Floods When Starting Warm Engine
    By ImpetuousNinja in forum Performance & Fuel
    Last: 05-30-2008, 10:59 PM
