    Default 2009 work truck - brake noise
    I'm getting a persistent squeak from the driver side rear brake upon release of the brake pedal.
    The brakes make no noise, simply a squeak on release only.
    Any idea's ?
    Disc or Drum, Either way i would lube up all the moving parts and contact points first easy and cheap fix
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    when the brakes make noise when the pedal is NOT depressed then the pad wear indicators are causing the issue. soon these indicator clips will fall off and the noise will go away
    Mar 2013
    Franklin, TN
    Take off the DRUM and lube the backing plate lightly where the SHOE moves against it.
    2010 Silverado 1500 LT Crew Cab 5.3
    Quote Originally Posted by Trucking View Post
    My rear brakes on my 05 squeak when backing up. Thanks for the tip, I'll check this.
    Lerch
    This is Chevy Country.
    Last: 03-07-2012, 10:30 AM
  2. brake light only work when truck is off
    By 85lt250r in forum Chevy Truck Talk & GM News
    Last: 01-25-2012, 07:05 AM
    Last: 11-15-2010, 04:30 PM
  4. Replies: 0
    Last: 08-15-2009, 04:20 PM
  5. Replies: 0
    Last: 07-12-2009, 09:20 AM
