Results 1 to 10 of 13
    Default Need brake help; soft pedal
    need help put in a new master to fix soft brake pedal no good keep going to the floor bleed them 1/2 of gallon
    of fulid all 4 no good can u help,
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Welcome to the Club!!!
    I moved your thread to the correct section and modified your title to fit your topic. This will help you in getting more response/opinions.
    Good Luck!
    TIRES:
    BFG All Terrain KO 315/70/17
    did you bench bleed it before you installed it? if not then that is most likely your issue.
    this was my thought. The master needs to be bench bled first.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    same issue on my truck, though i paid someone to do it... so you can imagine my frustration.
    i had 3 different shops bleed the truck, including the chevy dealership before we find a wheel clynder was cracked!
    after changing it and trying again the pedal seemed to be fixed........ now im back to square one with a mushy as hell pedal... new master, new rubber lines for the calipers and axle, and new wheel clynder...
    its obvious there is air in the system but how its creeping in perplexing... pisses me off... any ideas?
    After this I might think that there is possible a soft spot in a brake line. so when you step on the brake the rubber hose bulges/expands. Not sure the easiest way to inspect this other than having someone put pressure on the lines and then visually inspect. Also maybe physically squeeze the lines to check for softness (similar to a radiator hose). I would think if there was somewhere that was allowing air in it would also leak fluid out.
    What year is the truck? I'm not an expert with master cylinders but many are vacuum assisted. Be sure the all hoses are good and do not have any vacuum leaks.
    found the problem.... rear brake line end was cracked where it plugged into the wheel cylinder
    replaced both, now it seems to be ok....... but the ABS light is now on...
    found it because there was a never ending supply of air coming out of the bleed screw while the other side was solid fluid
    glad you found the problem as well @K15 Blazer Guy. May try resetting the ABS light and see if it comes back on now that you have fixed an issue in the braking system.
    i may just put a piece of electrical tape over the warning light lol XD
    i hate the ABS
    trucks today hardly let you control anything yourself. drive by wire. on star engine control. ABS. traction control.... all government mandated crap for people who dont know how to drive
    lol
  1. 2001 Suburban soft brake pedal compared to 2011 Silverado
    By bazar01 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-04-2013, 09:57 AM
  2. soft brake pedal ~ 99 K1500
    By 99 Z71 in forum Lifted & Offroad Suspension
    Last Post: 05-03-2011, 05:54 AM
  3. soft brake pedal!
    By kuz6954 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-02-2010, 11:31 AM
  4. Engine Missing/Brake pedal soft
    By lonewolf9861 in forum Member Introductions
    Last Post: 12-28-2009, 02:17 AM
  5. 04 silverado soft brake pedal
    By Rob L. in forum Lifted & Offroad Suspension
    Last Post: 10-29-2009, 02:16 PM
