    Default Seized 7.4L engine story and Question
    1995 GMC Sierra, Bucket Truck, 55,656 miles
    Story: 35 MPH #1 piston came apart and the connecting rod (which was still going up & down) beat the big pieces into little pieces; this smashing process bent the connecting rod until it punched a hole in the cylinder wall at which point the wrist pin lodged in the hole and stopped all movement.
    Purchased a Re manufactured engine (Mexico) with a flat tappet camshaft that needs to be broken-in properly, which leads to my question:
    When this engine starts for the very first time, would a new oxygen sensor be damaged by the burning of oil in the cylinders; I'm thinking of leaving the old sensor in until after camshaft break-in ? ? ?
    My History, I was born in 1946 and stopped working for an employer in 2010. I served aboard the USS INTREPID CVA11 in the 1960s. The Intrepid is now a museum in NYC. As a former crew-member I did volunteer duty on board 2009 & 2010.
    Last Year I volunteered at a water powered mill in Wilmington, DE.
    In 1993 I replaced a (4.3L) 267 cu.in. SB with a (5.7L) 350 cu.in. SB in a 1979 Chevrolet Malibu wagon (everyone called it a sleeper). That was the extent of my engine swapping until now.
    My SON just bought an electrical business from his employer who was getting out of the trade; the bucket truck was part of the deal. Less than a year later the engine seized and he wasn't getting the work he was hoping for (no money for the bucket truck). Enter volunteer DAD with the money for the engine and the tools to do the work.
    Thanks for any advice !Click image for larger version.
ID:	51810Click image for larger version.
ID:	51811Click image for larger version.
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    Good story and I hope buisness picks up for your son. I do not believe the extra oil would damage the sensors but since you are replacing them and have the option to fire and run on the old ones, I would and swap them out after it is running ok.
    Thank God for dads (I think that's what my kids say)
    Welcome aboard.
    I would run it with the old O2 sensors in, I don't think that the oil will damage the new one, but why risk it.
    I have to say, the part that interested me the most about this post was the picture of the shattered piston. "Wife's Fry Pan" Lol If I did that, I'd be sleeping on the couch for awhile.
    Jun 2006
    Gotta agree with James.
    BEFORE I was married-1980 maybe
    I read something about lubing a motorcycle chain by putting it in motor oil-then heating the oil
    Yeah-put it in a BIG frying pan-on stove-electric.
    Horrible odor in apt-but it gets worse
    It caught fire-duh oil burns-especially hot oil.
    Didn't have a lid to smother it
    so I tossed a few lbs of laundry detergent on it
    Freakin mess
    My girlfriend-now wife- saw my not great clean up job-
    Hmmm married me anyway-but in 1984!!
    In any case-yeah leave those sensors in there-and being machinery oriented-and old-(I'm only 62 you are an older duffer than me!) you will be concerned with oil supply
    The break in usually has something about pumping the oil around the engine BEFORE starting it
    Most folks don't have a way of doing this
    So I just crank the engine with the plugs out-so not much load on anything-use engine oil pump to pump oil around
    Gotta pump it quite a bit-many hits of starter(charge that battery up-or have a second one ready)-1 minute or more of "run time"
    Bet someone here has a better "shade tree way to do it"
    Think I also would pull valve covers smear assembly lube on stems etc"-maybe spray lube from under engine-oil pan off-smear spray assembly lube everywhere.
    Luck
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
  1. SUV seized in RBC firebombing - CBC.ca
    By Steve in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last Post: 05-28-2010, 12:40 AM
  2. 4x4 shifter seized
    By jimmy979 in forum GM Powertrain
    Last Post: 05-23-2010, 01:35 PM
  3. She's seized :(
    By crane557 in forum GM Powertrain
    Last Post: 04-05-2010, 08:50 AM
  4. I think my motor seized this morning!?!
    By stavropulos in forum GM Powertrain
    Last Post: 04-04-2010, 06:51 PM
  5. Engine Seized Up-1990 Suburban
    By CMCM in forum General Chevy & GM Tech Questions
    Last Post: 09-29-2008, 12:03 PM
