    Smile 2004 Chevy Problem with the "Clunck" noise
    Steering clunck noise when driving slow and turning the steering wheel. Just had to post the fix for this problem. Since I am new, it may be an old fix, but bear with me if so. This thing was driving me nuts. Clunck, clunck everytime you turned the wheel. Of course everybody I took it to said, it won't wreck you, it is safe. Drilled and tapped a grease fitting just above the main bolt connecting top to bottom and filled it with grease. Drove 10-15 miles and it is gone. Yes gone. Anyone need specifics, e-mail and I will pass along.
    Moved to maintenance tech***
    Welcome to GMTC! Thanks for the helpful post. He is a link discussing the same repair, page 2 post#20
    http://www.gmtruckclub.com/forum/sho...ng+shaft+clunk
    Yup, the zerk fitting is the way to go. Sadly, the 'engineers' at GM haven't figured this out, as their kit STILL lacks one.
    Love to have the specifics for this fix. Seems a whole lot simpler than the other one posted as a sticky...
    I'll send a private message.
    2006 Vortec Max 1500
    Performance:
    Other:
    -Spray-in Bed Liner
    Any one know if this will help with the steering wheel making a howling noise when slow turning?
    Nope, chances are your howling noise is only when turning left. If that is the case then it is the gear box.
  1. 2005 Yukon XL "Growling" noise when turning left.
    By Pikey in forum General Chevy & GM Tech Questions
    Last Post: 04-10-2013, 12:42 PM
  2. Weird "grumble" noise at part throttle...
    By travisn in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-10-2011, 09:47 PM
  3. Hi All and First Question - 2006 Silverado "Tapping Noise" when driving.
    By brianbittner1 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-13-2011, 04:36 PM
  4. "sucking" noise from tranny and shaking TC lock-up??
    By mateospeed in forum GM Powertrain
    Last Post: 02-11-2010, 07:00 AM
  5. 2004 Yukon Steering noise problem
    By jennmw in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 10-26-2006, 04:20 PM
