Results 11 to 12 of 12
    you really wont notice much unless you are coming from the 4.3 v6 with 3.43 gears like me lol i upgraded to 4.10s and am theoretically left with a little bit more power than stock according to my tire size to gear ratio.
    Quote Originally Posted by wmkess View Post
    Ah, I totally forgot to consider the extra weight that comes with larger tires! Were the wheels also bulkier as well? I plan to keep my factory wheels.
    I hear this all the time when people talk about getting bigger tires and wheels. more than likely 99% of people getting aftermarket tires and wheels will be getting aluminum wheels which is always significantly lighter than the factory steel wheels, regardless, the only thing thats going to affect your mpg is tire size AND tire width...
    weight of a tire??? unless each tire is about 200 pounds heavier than you will never notice a single difference simply because of the weight of the tire...
    thats like saying you lose 2 mpg just because you have a person in the passenger seat...
    a simple 10-15 pounds extra to each tire on a truck is like adding a tank top on your body, it aint gonna change anything about your power...
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    the more you increase the height the more the MPG drops. the bigger and heavier the tire the load increases and MPG drops.
    a tire with low rolling resistance will increase the MPG. AT tires you get better traction but loose some MPG when compared to the passenger tires that have the low rolling resistance , but you loose traction in difficult road conditions.
    with the AT tires I have I have never had any problems in the snow . I know if I switch to the low profile low rolling resistance tires I could get a little more MPG but I got a truck to get me to work in the snow so the AT tires will stay . depends what your looking for in performance with a truck .
    agreed as there is alot that goes into it.
    Using my truck as an example I went from 3.73 (31" tires) to 4.10 (35" tires) when I lifted it. I did the 4.10 (which is taller than a stock effective gear ratio) because the truck was my daily driver and mostly highway mileage. The 4.10 kept the rpms low on the highway and I actually lost no mpg after lifting (an oh so awesome 12mpg). In all honesty if I were to do more towing or lived in an area in the mountains again the 4.56 would be a much better option for me. Now to the tires part. My stock wheels were actually very light and I used those for a while with the 35" tires (and they were all terrain tires). I later switched rims and tires (still 315/75/16), once again rims were not very heavy but I went to a hybrid AT/MT tire and I lost about 1 mpg with that change. I only had highway tires in the stock form for 10 days (truck was then stolen and when I got it back I put all terrain tires on it as the smugglers put a beat up set of off road tires on it), and with the 1 or 2 tanks of gas on those I had maybe a 1-2 mpg increase over the all terrains. Unfortunately lots of factors go into mpg like the 10% ethanol in gas or the summer and winter blends here in CA.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  1. Changing one ton truck tire size
    By donniebr in forum Chevy Truck Tech Forum
    Last: 09-05-2012, 03:44 PM
  2. changing tire size on diablo sport
    By Pflor86 in forum Performance & Fuel
    Last: 03-19-2011, 01:46 PM
  3. Changing tire size
    By t75atc in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-24-2010, 04:17 AM
  4. Tire diameter impact on mileage?
    By raueda1 in forum General Chevy & GM Tech Questions
    Last: 08-19-2009, 03:48 PM
  5. Tire Diameter and fuel data
    By buckeyesalt in forum General Chevy & GM Tech Questions
    Last: 07-24-2009, 05:39 PM
