    Cool going to removed truck bed
    what size are the bolts that hold the bed on a 98 k 1500with a six foot bed & how many are there? The reason i removing the bed is to replace the fuel pump
    change the exhaust & replace the rear shocks. Also i am going to clean up the frame rust proof it . Any tips on removing the bed will be helpfull .
    thanks
    crazyforgms
    not sure on the size but im pretty sure gm likes the 6 bolt set up if i remember correctly i think mine is 6 bolts and i doubt it changed from your to mine, if so, im sure someone else will chime in
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    lol, yeah, I'd actually thought of something like that except it's a dually so anything holding the front of the bed from underneath would be in the way of the wheels rolling out.
    Finally broke down, guess I'm going to have to buy a bigger engine hoist, found one big enough to reach over to the middle of the bed from the rear of the truck. Guess I was just trying to find a cheap-skate way out!
    2013 MERCEDES BENZ SL-CLASS
    thank there was six i got the bed off know i am cleaning up the fram
    Back in December, my dad and I removed the bed off my 2001 Siverado so I could change the fuel pump. It had six bolts. We used his John Deere tractor to lift the bed once we unbolted it - made things pretty easy. But yea, should be six bolts.
    Did the same thing with mine! Only my dad wrapped chains through the fender wells with towels for protections mod completely bent in both sides of the bed lol
    Yeah, my dad's got several attachments for the front end of the tractor. We put the forks on the front and hooked chains to the tie down loops in each corner of the bed, then looped the chains over the forks and lifted.Click image for larger version.
  1. Removed my BUL BAR today.. What do you think with it off?
    Last: 02-27-2012, 02:28 PM
  2. More ads have been removed for registered members
    By ChevyFan in forum Announcements & Feedback
    Last: 11-11-2011, 11:42 AM
  3. Removed Flowmaster
    By groceryman in forum Chevy Truck Accessories
    Last: 08-30-2009, 05:49 PM
  4. Removed fuse and DRL still works -
    By sstoner911 in forum General Chevy & GM Tech Questions
    Last: 06-03-2009, 04:15 PM
  5. Removed lettering from doors
    By RatRod in forum Chevy Truck Accessories
    Last: 12-30-2007, 03:39 PM
