Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Ecoboost Issues
    Nov 2011
    Central Illinois
    Default Ecoboost Issues
    Not sure if this is the best forum but I found the article interesting. I am VERY glad GM chose to not mimic Ford and stayed away from small displacement turbo engines.
    http://www.foxnews.com/leisure/2013/...ine-defective/
    2012 Silverado 1500 LT 4X4
    2003 Suburban LT 2500 6.0L
    But GM went with Active Fuel Management and lots of those egines have died...
    Quote Originally Posted by paracutin View Post
    It is a matter of time that twin turbo engines start giving their owners problems.
    How many AFM engines have died of the ~4 million made since 2007? 300, 400, 1000? Can all those engine deaths be attributed to AFM killing it? If AFM on the 5.3L and 6.2L engine was such a bad thing, GM would have discontinued it.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    AFM has only caused slight to major oil consumption issues not any other issues. Ford Twin turbos have had problems like setting fire to themselves and almost killing owners which is much worse than needing to check your oil more often and top it off.
    I good friend of mine owns a repair shop and has said that in his experience if an AFM engine owner uses synthetic oil, their oil consumption goes down dramatically. I imagine AFM oil consumption is one of the reasons GM mandates their customers to use dexOS approved oil.
    Mods:
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    I still dont feel like turbo technology has come far enough to have reliable longevity to it. All those VW turbos only last to around 70-75k tops around here. Then ford says "we dont just have 1 but TWIN TURBOS!", i would hate to own one once the warranty stops cuz thats gonna be a second mortgage on the house to fix.
    01' 1500 LT Z71 ECSB 5.3L
    Nov 2011
    Central Illinois
    I have never owned a diesel truck but all modern diesel trucks are turbo charged. Any issues with the turbos?
    The Duramax diesel engine is turbo charges, and it has IIRC a two stage turbo charger.
    Mods:
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    The new ones are vari-vane set ups that adjust boost by pitch of the vanes. They have more of a prob with the vanes getting carboned up and not moving anymore. The diesel turbos are biult better since a bad turbo can cause a runaway if oil get past the seals but they still need changed out often. My old boss had a 07 cummins that started making noise at 30k miles but i dont work there anymore.
    Former Member
    Apr 2012
    Reading, PA
    No problems on the standard old mechanical diesel turbo...but the newer variable geometry turbos and the electronically controlled variants have some problems time to time. I had 200k and 275k on my last two Cummins (respectively) and my father has 300k on his Cummins without issue...and I wasn't easy on the last truck.
    One thing to keep in mind regarding turbos...they take an oil specified for turbo engines. Pretty much every diesel on the road today is turbocharged, and the oil for a turbo diesel is a lot more stout than an oil for a gasoline engine, and not all gasoline engine oils are turbo-rated. If you get the wrong oil, it might not fail right then, but it takes time of the useful life of the turbo.
    Turbos on gasoline engines have been around a long time...look at the Grand National and GNX, they were turbo charged V6s and were probably the hottest car in their heyday. Some of the Subarus are turbo charged (my Forester is one), and they typically only have turbo problems if the owner neglects oil changes and the oil passages plug from oil coking. My Forester gets 20mpg in town and 26mpg+ on the highway...and is one nasty little sleeper (its light, the turbo spools quick, and all wheel drive).
    FWIW: I have driven the Ford Escape with the 2.0L Ecoboost...very similar in size to my Forester. It netted me 35mpg+ on the highway and had plenty of zip. Ford's got a good idea with the turbo-charged cars, just bad implementations (hey, every manufacturer gets a bad run of parts or has issues in the first couple model years).
    The one that really gets me is the F150 with the EB3.5L, there is an application that screams fail to me every time I see one...that's working the engine pretty hard to maintain the power of a comparable V8.
  1. What your opinion on the new Ford EcoBoost
    By Conlan Rose in forum The Coffee Shop ~ Chit Chat
    Last Post: 01-18-2012, 08:46 AM
  2. Replies: 0
    Last Post: 03-25-2010, 12:50 AM
  3. Ford Flex's EcoBoost: More Power, More Fuel - Wall Street Journal
    By Steve in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last Post: 10-17-2009, 05:00 AM
  4. Review: 2010 Ford Flex ecoboost turns it up to 11 - Autoblog (blog)
    Last Post: 10-12-2009, 04:30 PM
  5. First Drive: 2010 Ford Flex EcoBoost delivers more than just a ... - Autoblog
    Last Post: 07-21-2009, 11:30 AM
