    Default noise from under hood
    my belt is squeaking and the water pump pulley has some vibration. 2000 chevy 1500. my question is would replacing the pulley be a fix or would i need to replace the whole water pump
    Chances are that the vibration is due to a bad bearing in the pump not a bad pulley. I don't know that I have ever seen a water pump pulley go bad.
    yea after some reading that what i came up with. so now the water pump needs replacing
    Quote Originally Posted by springtb View Post
    remove the belt and check all pulley bearings , also before going to buy the parts .
    noise under hood= awesome american V8
    .... if you can wiggle the fan, the whater pump is shot. sounds like it is.
    Sorry for never updating on the post. turns out that is was the water pump because it went out that afternoon a block from the house. Replaced it that night now it runs like a champ!!!!!!
  1. Hood pins on carbon fiber hood
    By j5689 in forum Chevy Truck Accessories
    Last: 12-22-2012, 12:51 PM
  2. First offender making noise about Watertown?s new noise ordinance
    By Enkeiavalanche in forum Audio, Video & Gadget Tech
    Last: 09-15-2011, 08:25 PM
  3. Clicking/Ratcheting Noise under hood from A/C
    By JAnderson2 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-23-2010, 10:16 PM
  4. Strange noise under the hood
    By jediracer in forum GM Powertrain
    Last: 07-08-2009, 10:17 PM
  5. 1500 hood vs. 2500 hood
    By kuz6954 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-01-2009, 05:28 PM
