    Jr. Mechanic Bowtied's Avatar
    May 2009
    2004 Silverado 5.3L
    Default Any way to test the water pump with engine off?
    Hi guys, I was explaining my plight with my recent thermostat replacement (that worked for 7 days then water started leaking from the water pump area of the truck) to my friends dad and he said i should test the water pump by trying to spin the radiator fan while the engine is off.
    I didnt understand what he meant by this but is anyone familiar with what he might be referring to and whether this would work on a 2004 silverado?
    He also mentioned that if the engine had alot of electronics on it, that trick may not work as it might've been for older more mechanical based engines.
    Just to clarify the title i mean engine off not out, as in, engine installed truck off, not engine off the truck :-p
    I think he means take the belt off and check to see if the bearing is wiped out. Try that and rent a pressure tester from az and look for leaks. I have been smelling coolant lately so im in the same boat, just havent had time to check where its leaking.
    01' 1500 LT Z71 ECSB 5.3L
    Why not tell us what M&Y???
    May 2009
    2004 Silverado 5.3L
    Quote Originally Posted by redvett View Post
    my bad, i thought i mentioned that.
    its a 2004 Silverado 1500 5.3L 2wd
  1. Water pump leaking?
    By JRD761 in forum General Chevy & GM Tech Questions
    Last Post: 12-12-2010, 08:39 PM
  2. water pump
    By 250rman79 in forum General Chevy & GM Tech Questions
    Last Post: 10-31-2010, 03:43 PM
  3. water pump pulley
    By engineerbrian in forum General Chevy & GM Tech Questions
    Last Post: 07-18-2010, 05:34 PM
  4. How to remove a water pump
    By BigFish in forum General Chevy & GM Tech Questions
    Last Post: 03-31-2010, 11:59 PM
  5. WTB: Water pump
    By 95burban in forum General Classifieds
    Last Post: 01-11-2009, 04:15 PM
