Results 1 to 10 of 13
    Default I need an Evaporator Coil removal how to.........
    Hey guys - new to the site.
    Anyone have a how-to for a AC evaporator coil removal on a 99' Suburban. The upper connection was tight on the accumulator and I must have cracked a weld or something as now I have a leak just behind the firewall. I understand the entire lower dash has to come out - I'm just looking for a step by step (or at least the important steps).
    Thanks,
    Maury
    See if this helps you:
    EVAPORATOR & HEATER CORE
    Removal & Installation
    1) Disconnect negative battery cable. Discharge A/C system,
    using approved refrigerant recovery/recycling equipment. Drain cooling
    system. Remove glove box. Disconnect electrical connectors, if
    necessary. Remove floor air distribution duct.
    2) On diesel models, remove Powertrain Control Module (PCM)
    and mounting tray. On all models, remove trim panels. Remove blower
    motor cover. Remove blower motor-to-case screws, and remove blower
    motor. Loosen steering column bolts from instrument panel. Remove
    carrier and body bracket bolts supporting instrument panel (located on
    firewall and at each end of instrument panel). Tilt back or remove
    instrument panel as necessary.
    3) Remove coolant recovery tank. Remove heater hoses at
    heater core. Disconnect inlet and outlet lines at evaporator core, and
    cap openings. Remove accumulator. Remove A/C-heater assembly-tofirewall
    screws and bolts. Remove A/C-heater assembly from vehicle.
    4) Remove heater core cover from A/C-heater assembly. Remove
    heater core and seal from A/C-heater assembly. Remove air distribution
    lower case. Remove evaporator core from A/C-heater assembly. See
    Fig. 3.
    5) To install, reverse removal procedure. Add 3 ounces of
    clean refrigerant oil to evaporator. Lubricate NEW "O" rings with
    clean refrigerant oil prior to installation. Fill cooling system, and
    check for leaks. Evacuate, charge, and leak test system.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    Gary, you are the man! It's as involved as I expected. Wish me Luck.
    God, I love the internet!
    Maury
    Hey there;
    I am replacing my evaporator core at least attempting to but I have a couple of questions regarding the steering column removal.... Do you need to do this or is there a trick to get around this.
    also the instructions say remove the Hinge pillar trim panels Is this the pipe that goes across the entire dash? I am trying to get the process on how to gain room to access the evaporator case before I pull the dash apart. I have a 1996 K1500 Suburban with front and rear heat\AC I am only working on the front evaporator.
    The instructions I have is from ALL Data, I pulled from the local library. Any help would be greatly appreciated.
    Quote Originally Posted by maury View Post
    Maury
    There are two bolts at each end of the dash that need to be removed the dash can then be rotate on the hinge pins. some of the other small bolts may have to be removed to just let the dash release. I took mine out of the top with a friend helping.
    David
    what good is this gary if there are no pictures and figures that you refer to
    Probably doesnt matter since that was a year ago
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Apr 2011
    Wylie, Texas, United States
    I am curious about the steering column. Is this only to free up the dash for removal? I plan to start this job tomorrow or Monday on my 95 Chevy Silverado. I need the evaporator, and figure after all that trouble I should change the 16 year old heater core as well.
    Thanks
    Maury (the other Maury)
    As it just so happens, I helped my uncle pull the dash out of his 99 dually yesterday. The steering column has to be removed to allow the dash to drop. I wasn't around for that, but my uncle says it was a pain. There are 7 bolts keeping the dash from rotating on the lower dash pins, 3 along the top heater vents, 1 on either end of the lower dash, and 2 around the passenger airbag area. That gets the dash to tilt down. Then you have to pull the air duct which is held in by 1 bolt on each side. Then, to get the dash all of the way down, you have to pull the wiring harness off the dash. Then the dash can be removed and the a/c box accessed. We didn't get to pulling the a/c box out, but it looks like it's going to require pulling the dash support plate off and a big bolt holding it to the firewall. This is definitely NOT something that can be done in a day. Allot at least 2 days to complete, quite possibly 3.
    Christopher
    Quote Originally Posted by GaryL View Post
    Fig. 3.
    Any suggestions on replacing the rear expansion valve in a 99 suburban? I have the interior and all screws apart but i cant reach 2 screws between the fender and the black rear evap housing. I cant imagine I would have to disconnect all the lines from underneath? especially since service bulletin mentions cutting a hole in the box. How can i get to the last screws?
  1. Replacing ac evaporator core
    By rondo in forum General Chevy & GM Tech Questions
    Last Post: 03-23-2010, 10:22 PM
  2. Replacing Fuel Tank Evaporator Control
    By Poncherello in forum General Chevy & GM Tech Questions
    Last Post: 09-01-2009, 01:37 PM
  3. Evaporator replacement--'03 Silverado 2500HD
    By thpnalb in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-01-2009, 06:57 PM
  4. Removing evaporator coil out of a 95 Z71
    By billywilly in forum Chevy C/K Truck Forum
    Last Post: 05-03-2008, 06:13 PM
  5. evaporator coil removal on 95 gmc z71
    By billywilly in forum General Chevy & GM Tech Questions
    Last Post: 05-03-2008, 05:02 PM
