Results 11 to 19 of 19
    Quote Originally Posted by outdoorsboy87 View Post
    Hey guys new on here this is the first forum that i have been part of. I have a question about towing and wanted to see if anyone else has had the same problems that i am having with my truck. I have a 2008 chevy silverado regular cab with the 4.8l v8 and i am having a problem when i tow my boat. Now this isnt a big bay boat or anything its a 16' aluminum jon boat that might weigh 1600 lbs at the most. i have noticed that when i am crusing at 70mph at about 1800rpms the truck will down shift and the rpms shoots up to 3000 rpms and this is on flat highways around the houston texas area. i have also noticed that the transmition temp goes from about 165f to around 195f. Is this a major problem? When i bought the truck i didnt get the towing package could this be why i am having trouble also? and the truck does the same thing when it is empty going through the texas hill country. Thanks in advance
    Did your truck come with the towing package(cooler, hitch, wiring harness)?
    Quote Originally Posted by Barnettamb View Post
    How do yal know the temp of your transmissions?
    The transmission temp can be gotten from the DIC. Seeing as you have a 4.3L, I think you have a W/T and the DIC is there, you just need to get the DIC buttons.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    i do have a w/t but i dont know what the dic is
    2007 Chevy
    Reg cab
    2wd
    4.3 v6
    32'' bfgoodrich all terrains
    If they don't sing, they don't sling.
    My 2007 has the DIC panel (Driver Instrument Cluster) that displays information like tranny temp, and fuel range...
    "War Eagle"
    **stchman beat me to it ;)
    2007 Silverado 1500 LT Ext Cab 4.8l, 2007 Suzuki XL-7, 2012 H-D Sportster "Seventy-Two"
    The DIC stands for:
    Driver Information Center
    To enable the full function of the DIC, you'll need the DIC buttons.
    http://www.ebay.com/itm/2007-2013-Sl...19ae20&vxp=mtr
    The DIC wiring is behind your dash when you pull off the cover, you just need to hook it up to the switches.
    Mods:
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Final tally on tranny temp for my trip, when I went through Mt Rushmore, due to my inexperience of manually downshifting, I overused my brakes and thought I might go off a cliff...lol not really that bad but definitely had a few pucker moments. I reached temps of 206 with outside temps of 85-90 degrees.
    The next day when I was driving through the Rockies I manually downshifted every time I encountered a downhill segment, and actually saw my tranny temp decrease, and then rise again as I would climb the next segment. the highest temps I saw climbing were 212 in steady 90 degree temps. The last day was a scorcher with temps around 105-106 and going through the Mt Rainier area of WA my temps jumped to 221 on the worst climbs. Once again I manually downshifted on the downhill segments and the temps dropped a little.
    If I were to do this trip again, I would seriously consider the all-wheel disc upgrade. My current brakes are also 6-7 years old never been reworked, but only have 40k miles on them. They seemed very inadequate pulling the trailer and bike through the mountains, until I got comfortable downshifting that is. I would also re-read the operator manual and know exactly what my manual shift points/speeds are.
    I hope my rambling on puts some perspective on tranny temps, and what to expect from your ride.
  6. Thanks JTWard thanked for this post
    Likes JTWard liked this post
  7. #16
    Sr. Mechanic JTWard's Avatar
    May 2013
    Thumbs up
    Glad your trip was OK. I'd give your truck a gift of slotted discs and ceramic pads on the front end. Your temps are fine, my truck runs at about 200 degrees in the summer or winter, no difference, my other car (also a GM) will go to 210-215 degrees if it's 100 degrees outside with 75% humidity. so I wouldn't fret over you temps, You truck is running perfect. I am planning on the brake upgrade I mentioned come fall. When I'm towing in high temps I can feel my front brakes getting hot and slipping, so I'm going with better disc's and pads.
  8. Likes MoBillyAla liked this post
  9. #17
    Quote Originally Posted by MoBillyAla View Post
    Great Post! Like the detail ...Good info for folks looking to do what you did for the first time... Good Job!
  10. Likes MoBillyAla liked this post
  11. #18
    Quote Originally Posted by JTWard View Post
    I agree, There are a lot of twisty up/downhill roads here in NW WA and I think my truck would feel much better with an upgrade like that with or without pulling a trailer. Still trying to get settled in my new house and pay off some moving expenses, but will start looking at getting some of this done soon.
  12. #19
    May 2013
    They are a real upgrade for the front end of your truck. Most of your braking power is on the front wheels. The ceramic pads need to be broken in or cured after installing them, not complicated, but the ceramic pads give off very little dust, but the best thing about them is the hotter they get, the better they brake your trucks speed, No fade !
  1. another towing question. Am I ok? 2008 Silverado 1500
    By Joes08 in forum General Chevy & GM Tech Questions
    Last Post: 08-22-2011, 09:20 AM
  2. Towing Difference in 2008 and 2009 Silverado
    By sully428 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-19-2009, 10:42 PM
  3. isimple ipod adapter problems 2008 chevy
    By hmaster77 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-29-2009, 05:58 PM
  4. Active fuel management problems 2008 Chevy Silverado
    By hd2500407 in forum Performance & Fuel
    Last Post: 05-09-2009, 07:59 PM
  5. Towing Question - 2008 Silverado Crew Cab
    By cigar_stub in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-28-2009, 04:10 AM
