Thread: Clunk sound
    Default Clunk sound
    I have a 2009 Silverado with 26k miles. When I pull up to a stop and sit for awhile I get a clunk sound and it feels as if someone has hit me from behind. I'm guessing it is coming from the transmission--maybe the torque converter down shifting?? Does anyone else have this problem, if so-what did you do to correct it?? Sometimes it happens right away and sometimes it happens a few minutes after sitting for a red light. Any help out there?? Thanks!
    this is a VERY popular topic with our trucks, use the search feature...
    it is your slip-yoke, you must apply some lubricant to it
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    Quote Originally Posted by Ruby Red View Post
    I had this occur when my truck was under warranty , they replaced the transfer case fluid and the clunk disappeared for about 40,ooo mi so I replaced this transfer case fluid again and no clunk.
    service manager stated it is because the fluid looses it lubricating abilities and the drive shaft will not slide when first starting to move at a stop like a light//stop sign ...I had it do it mostly when it was cold out at first.
    Thanks for the help! Yes, it was the slip-yoke. I dropped the drive shaft, lubed the splines on the yoke, put it back together--clunk gone for now!! Thanks again.
    I would check the transfercase fluid to be a nice blue color. if its getting a grayish color replace this fluid.
    most replace this fluid in work trucks every 40,ooo mi. or sooner like plowing etc..
    good advice, but mine is two wheel drive!
    You need a nickel plated slip yoke, put one on mine almost 4 yrs ago and not probs since.
    01' 1500 LT Z71 ECSB 5.3L
    since it is 2wd with what you did should take care of it,...
    I would think so, the plating allows it to move easier so it shouldnt matter if its going into a tail housing of a transmission or a transfer case.
    Aug 2011
    Long Island, NY
    Any idea of the cost of the part? Did you install it yourself or have a mechanic do it? Thanks
    2004 GMC Sierra SLT Z71, Truxedo Low Pro QT tonneau cover, Rhinoliner bed liner, Putco side rails, Weathertech window deflectors and floor mats, AMP Research bed extender, GMC cloth seat covers, light bar, lights and more to come.
  1. 04 Suburban Weird Whine Like Sound ONLY When Under 20KM over 20 no sound
    By TechAnalyst in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-29-2011, 05:20 PM
  2. clunk sound heard under truck when braking
    By humnbass in forum General Chevy & GM Tech Questions
    Last: 12-22-2009, 06:27 AM
  3. clunk sound when put in gear???
    By Nicholas23 in forum GM Powertrain
    Last: 09-23-2009, 06:33 PM
  4. Clink/Clunk Sound
    By Tdaz250 in forum Lifted & Offroad Suspension
    Last: 08-12-2009, 09:47 PM
  5. Replies: 0
    Last: 04-19-2008, 10:46 PM
