Results 1 to 10 of 15
    Jr. Apprentice Arbitert343GS's Avatar
    Oct 2010
    Lawrenceville, Ga
    Default Engine misses while driving and poor gas mileage
    I have a 1999 Chevy C1500 with a 5.7 and while driving my engine misses(tach bounces around), but at idle its ok. Also Im getting like 7 MPG and I have no check engine light on. What might be the cause of this?
    Brandon - Georgia
    1999 Chevy C1500
    1978 Pontiac Trans Am
    Spark plugs and wires would be my 1st check!
    Oct 2010
    Lawrenceville, Ga
    Sorry, I forgot to say, I also just put new spark plugs, wires, cap, rotor, fuel pump, and fuel filter on it.
    Oct 2012
    Saskatchewan
    I think I am having the same trouble as you the only thing that sounds different is when I first start it it sounds like it is missing also. I have tried a cap and rotor also as well as a fuel filter and ran some fuel out in a bottle to check for water in fuel but it looked clean. I am maybe thinking a fuel pump but don't want to change it and that not be the problem.
    2000 Chevrolet Silverado K2500 Crew Cab
    Jr. Engineer 4x4squared's Avatar
    Dec 2011
    Fort St. John, BC
    Quote Originally Posted by baumann6 View Post
    just toss a fuel press. tester on it and see if youre running in an acceptable range. another quick check you could do is grab a can of ether and while its idling, spray down your vacuum lines one at a time and see if your idle changes.
    remember, ethers not the best for your engine lol if you find a leak dont keep sprayin :p
    and check that air filter lol doubt its makin you miss but its overlooked a lot and for $10 its worth changing. if your truck cant breathe its gonna drop fuel mileage.
    5.7L 350| .420 Cam | Bored 0.030 | Edelbrock intake manifold | 600 Cfm Edelbrock Carburetor | Long tube headers | Shift kit | Chrome dress up kit | Flowmaster 40's exhaust | Edelbrock heads | Custom paint
    SOLD
    "Don't judge a book by its cover."
    HONORARY CANUCK
    Oct 2012
    Saskatchewan
    What is the proper fuel pressure for these trucks.
    Dec 2011
    Fort St. John, BC
    i wanna say about 10-13 psi for a tbi 350... not 100% sure though
    I would also consider checking your egr valve.
    For 1988 to 1995 the pressure is 9 to 13; from 1996 and up it is 60 to 66 psi. This is for V-6's and small block 8's.
    Sirwriter
    I would check your carburetor, vac lines, and oil. My truck was having difficulty and I rebuilt the carburetor and it started to work much better.
    1982 Chevrolet K10 Scottsdale
    5.0 Liter 350 Short Block
    Automatic/4WD35-Inch Tires
    15-Inch Micky Thompsons / 6 Inch Suspension Lift
  1. Poor Gas Mileage
    By jac in forum Chevy Truck Tech Forum
    Last: 03-08-2011, 01:19 AM
  2. 95 Yukon Low Power and Poor Gas Mileage
    By Smartin in forum GM Powertrain
    Last: 11-30-2010, 01:10 AM
  3. Poor mileage - Thermostat ???
    By kjb13 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-16-2009, 10:33 PM
  4. Poor Gas Mileage
    By Art in forum The Coffee Shop ~ Chit Chat
    Last: 08-14-2008, 02:41 AM
  5. poor gas mileage
    By green 1984 chev 4x4 in forum Member Introductions
    Last: 06-06-2008, 11:07 AM
