Results 1 to 9 of 9
    Default revived my anti-sway bar
    did this project two weeks back when I was home in san antonio...
    what i did:
    1) removed stock sway bar
Name:	IMG_2806 (640x480).jpg
Name:	IMG_2807 (480x640).jpg
    2) sandblasted it to removed all rust
Name:	IMG_2808 (640x480).jpg
    3) repainted it with rustoleum flat black paint
Name:	IMG_2811 (640x480).jpg
    4) reinstalled with energy suspension greasable polyurethane bushings
Name:	IMG_2813 (640x480).jpg
Name:	IMG_2815 (640x480).jpg
    I enjoyed this project
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    Good job
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Jun 2013
    Hi ,reggiecab2000
    I am agree with you,it is easy for handling.some more information about-Anti sway bar which reduces body roll for easier handling.Increases traction and control by distributing truck weight more evenly to both sides
    Ensures proper fit and correct ground clearance on lowered trucks. Constructed of hot-formed T4140 chrome-moly spring steel. Kit includes all hardware and polyurethane bushings for easy bolt-on installation.Anti-sway bars use the weight of the RV to create stability. You install the bars to the vehicle's frame and chassis. Anti-sway bars designed for a trailer's hitch and tongue also work similarly. They help reduce the vehicle's side-to-side motion by bracing the weight of the vehicle's axle against the chassis. The anti-sway bars distribute the recreational vehicle's weight evenly. The bar on each side effectively holds the vehicle when a gust of wind hits it.
    Looks Great!
    99 Gmc Sonoma SL 4.3L 4x4 Reg Cab Long Bed
    Good job.. Did you want to upgrade the bar also? A bigger bar does make a big difference.. When you reinstalled it did you keep the bar level with the axel?
    Good job man, looks a lot better.
    I had asked a question about upgrading the bar a few months ago on here vs replacing bushings.... the conclusion I came to was that it wasnt worth the extra money to replace the entire front anti-sway bar vs adding poly bushings which i heard our trucks respond well to, and the difference in thickness between my factory bar and the hellwig is only 0.02". But while I was doing this project and took my truck out for a test drive, i decided to do some slaloming in the middle of the road at about 40 mph, with no sway bar, then i did it again with the bar and poly bushings, and in all honesty I couldnt tell a difference..... Ive considered doing a rear sway bar from hellwig, but still ponder if it really make THAT much of a difference off roading, which really only seems to consist of beach driving for me lately...
    you don't have a rear now? Get one You will like it..
    correct, I do not have a rear one. I hear people say theyre awesome, then I hear they limit so much suspension flex, etc... But i do not do rock crawling and I dont think my truck has ever been in a situation where i needed extreme suspension flex.... I do the occasional mudding with my truck, by occassional I mean it varies... Could happen 2 times a month or once every few months, but nothing "extreme", everything else is just messing around in the beach sand, Like the occasional late night bonfire and some donuts in the sand afterwards.... But I have always valued anyones opinion who has one, and wonder the pros and cons, if your offering your experience???
  1. Torsion Bars or Anti-sway bars
    By JungleJim in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 05-29-2013, 10:40 PM
  2. Anti-Sway Bar/Stabilizer Bar Addition
    By Goldie in forum Chevy Truck Accessories
    Last: 04-08-2013, 04:11 PM
  3. Anti-Sway Bar recommendations
    By Lance915 in forum Lifted & Offroad Suspension
    Last: 01-18-2010, 11:11 AM
  4. Chevy's Revived Muscle Car - Wall Street Journal
    By ChevyFan in forum Other GM Cars
    Last: 10-10-2009, 09:32 AM
  5. old chevy fan revived
    By tommyboy in forum Member Introductions
    Last: 04-07-2009, 08:04 AM
