Results 11 to 14 of 14
    Wow-you literally fire spark AFTER TDC?
    Wow I didn't realize that was done-sure makes sense.
    You cam put 99% methanol in your tank for track
    then pump in regular gasoline-
    do you have to
    "tell" the ECM I'm using methanol or I am using 87 octane now
    or does your ECM do that automatically??
    Your injectors are BIG enough to pump methanol-not STOCK are they??
    Yeah this truck NOT STOCK- looks stock-until you pop hood
    guessing it doesn't sound stock!
    Thanks
    Charlie
    The tune is setup to pull timing slowly after 8psi. when it reachs 16psi its pulling all of it out and goin into the negatives to save the poor pistons.
    ive got an extra tank than whats in this picture but you get the idea
    3 gallons doesnt really last long towing a heavy load with all 3 of them nozzles.
    i run 93 oct and tuned for it.. then slowly added the methanol till i got to 100%.. i started out using -20* windsheild washer fluid and its ~33% methanol. ill throw in pure methanol for the track and use -20* WWF for towing since it helps keep the IATs cool.
    Ive also got 91# injectors and they are almost maxed out on high boost haha.. time to go bigger.
    -Jonathan
    2000 ECSB Silverado 2WD
    LQ4 with Isky 215 Turbo Cam
    4L80E KB Racing S475 Turbo Kit
    All I can say is
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Posting up a nitrous thread in the performance forum now.
    how do you like your meth kit>? im doing a kb set up with a 76mm turbo with about 12psi and plan on running there stage 2 kit.
    2004 gmc sierra ext z71 5.3
    PERFORMANCE...
    KB racing hot pipes 3.5" : 76mm turbo: 4l80e : Circle-d 2b multi disk :Walbro 400 : Racetronix Hotwire kit : TB coolant bypass : Nelson 91 Pcm : Tr 220 Cam : Brian Tooley double springs kit : Ls7 Lifters : Stage 3 heads : Custom Intake Manifold :80lb Injectors : Ported TB : 40k tranny cooler: Plx dm-100 gauge: Auto meter fuel and boost gauge:
    APPEARANCE...
    Custom Speedo : Leveling kit :Smoked led taillights and 3rd break light : Black projectors and fogs with hids : Blacked out grille : 33's on 16's : Clarion flip screen: sound que 12" subs: clerion 6x9's : Memhpis amps: Alpine componet set.
    Future mods... Detriot tru-trac, deviels own stage 2 meth kit, MORE BOOST!!!!!!!!!!!!!!
    Last: 03-07-2013, 11:10 PM
  2. 2007-2013 Silverado/Sierra Turbo Kit 4.8L, 5.3L, 6.0L, 6.2L
    Last: 02-25-2013, 07:40 AM
    Last: 01-08-2013, 01:00 PM
  4. 93 Silverado 2500 6.5 turbo diesel
    By Winlub2 in forum Member Introductions
    Last: 06-01-2009, 07:56 PM
  5. Turbo on a 2007 chevy silverado
    By McManus40 in forum Member Introductions
    Last: 02-06-2009, 11:46 AM
