Page 17 of 40 FirstFirst ... 7151617181927 ... Last Post byLast Post by
Results 161 to 170 of 393
  1. #161
    did the alternator a few months back, would have just replaced both idler and tensioner, but unfortunately rockauto sent me TWO idler pulleys.... so gotta get that exchanged for my belt tensioner, then thats next on my list. but i have an squeaking noise AND a horrible whine when idling or driving, so im really hoping itll fix it
    I ended up just replacing the entire tensioner. I could have gotten the bearings for around $5 from my former workplace and just changed them out, but as always I was in a rush. I was also getting a whine from my new power steering pump. It drove me crazy, plus when it was cold in the morning it would make a high pitched "squeal" but it was not the belt or pulley, it was fluid moving passed something in the system, it only did it turning left. So, I added this to it Lubegard 20404 Universal Power Steering Fluid Protectant. The noise stopped within a day and no more whine.
  2. #162
    thats the plan for me too, not just the pulley, the entire tensioner, actually though my whine has nothing to do with my steering geometry, i do not think my truck has ever had the power steering fluid flushed in its life..... thats on my to do list as well, but gotta look up some details so i dont mess it up.
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  3. #163
    If you know someone that can hook you up at a quick oil change place, that is the way to go for the ps flush in my opinion. I took mine to my nephew who runs one of those places. He has a machine that has a long hose with another hose attached about half the length of the long one. He put the hose down into the reservoir, the long tube pumps new fluid in while the short tube lines up with the return line on the side of the reservoir. The short tube sucks old returning fluid into the machine and the long hose pumps new fluid in. He had me turn the wheel a few times during the process. I think that i had him run about 2 gallons thru my system.
    I have done it myself by disconnecting the return line and putting it into a bucket. Then I just kept pouring fluid in the reservoir as it pumped out. i had someone inside turning the wheel. You just need to watch that you do not let the fluid get low enough that it starts to foam.
  4. #164
    Painted frame. Don't care for it so the bed is coming off and going to do it right tomorrow. Cleaned exhaust and cut above the rear end to dump under the bed.
    2009 Silvia~Superlift 6"~DropStars~Nitto Trail Graps~FSOR Catback~Madtunes Racing~4.10 gears~cleared headlights~hi-6
    NNBS SILVERADO BUILD
  5. #165
    Thought about mine today! lol!
    Excuse the rust..I USE my truck.
    "No matter how beat up or rusty a chevy is, no truck will ever look as good goin down the road wearin that bowtie!"
  6. #166
    I looked at mine! Lol
    Chuckie!!!
  7. #167
    I took of my side trim
ID:	56821Click image for larger version.
ID:	56820Click image for larger version.
    haulin ass wastin gas
  8. #168
    Going to be doing an oil change and fuel filter change on my truck today.
  9. #169
    Installed a new set of fog lights on the truck and cleaned my lights. Will be trying to check the alignment on the lights tonight.
  10. #170
    I had hazardous duty today, last minute errands for Christmas, and wound up dodging as best as one can, the falling ice from the over head power lines, I still took a couple of hits, I would have rather fought my way thru a store full of elderly blue haired ninja shoppers. lol.
    Life is short compared to history
    Rick (summitwhite11)
  1. What Has Your Truck Done for You Today?
    By jake's silverado in forum Chevy Truck Talk & GM News
    Last: 05-18-2014, 07:27 PM
  2. What have u done to ur GM truck today?
    By devilsalmostfree in forum Chevy Truck Talk & GM News
    Last: 06-07-2013, 05:01 PM
  3. Truck died twice today...
    Last: 01-06-2010, 01:13 AM
  4. Replies: 0
    Last: 12-29-2009, 08:00 AM
  5. My Private Part Died Today
    By Cableguy in forum Photo & Video Gallery
    Last: 07-23-2007, 01:06 PM
