    Default New Brake Booster Question!
    Hi,
    My truck was having the "SERVICE BRAKE BOOSTER" light in the DIC and the dealer says that the booster was bad... they gave me the part number and I ordered it by eBay... the Part No. is
    19209324
    The problem is the center pin (that connects or push the master cylinder) is very large (or is like 1 or 2 inches out) and I can't install the master cylinder. Look at the pictures... I don't know if I can do something or send it back to the seller. The item is new form the box, and I bought to a dealer in eBay.
    Thanks
ID:	52810Click image for larger version.
    "SERVICE BRAKE BOOSTER" is caused by low booster vacuum. What M&Y?
    the problem is the new booster is not the same as the old. if so you have the wrong part.
    if you want info about what the new part should be give your vehicle details. you can also look this up on the web to check that your part is correct.
    now your problem may just be a vacuum line to the booster as the problem .
    On some boosters that rod threads in/out to adjust but you would have to check your old one
    01' 1500 LT Z71 ECSB 5.3L
  1. 1999 Silverado brake problems; brake booster? help..
    By Nick_Escalante in forum General Chevy & GM Tech Questions
    Last: 09-07-2011, 01:43 AM
  2. Brake Booster Leak
    By r768 in forum Lifted & Offroad Suspension
    Last: 06-27-2010, 08:57 AM
  3. No Brake Booster Vacuume
    By Demick in forum GM Powertrain
    Last: 12-02-2009, 07:41 PM
  4. brake booster 99 6.5
    By airhead in forum GM Diesel & DuraMax
    Last: 07-27-2009, 10:30 AM
  5. Little help? power brake booster
    By jam3466 in forum Lifted & Offroad Suspension
    Last: 06-22-2009, 09:17 PM
