    Question Weird O2 sensor readings
    Recently I bought an OBDII Bluetooth adapter to monitor my Tahoe's engine performance and see extra/more exact info from the ECU. Currently my o2 sensors are giving conflicting readings.
    What do I mean? Well the pre cat sensors at idle were reading a F/T of -1.6% for both the 1x1 and 2x1 sensors. While the post cat sensors are reading a F/T of 99.1% for both 1x2 and 2x2 sensors. Based on the info I've learned these readings are impossible. Does any one have an idea whats up with these readings? I have been getting a p0340 cat three way inefficiency code for the pass side cat recently, but the code keeps going away even tho its a major code that should stay in the ECU for a long time.
    Pic from torque app at idle:
    the P0430 code indicates that you have an air leak on the passenger side, or the cat is bad, or that passenger side rear O2 sensor is not connected to the wiring harness, or the wiring is bent, broken, melted, burned, etc...
    what is the F/T reading supposed to be of?? it's not fuel trims, because the fuel trims don't go that high...
    06MonteSS
    2014 Camaro SS - 2SS, RS pkg., short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake
    Is it possible that the reading from the rear sensors isn't actually fuel trim like the fronts and it wrong because they don't measure fuel they measure % of co2, co and o2.
    Also my p0430 code goes away on its own sometimes and only sporadically shows up. It makes trying to figure out what I need to fix very hard. Also the pass side used to have a weird sound for a while, which is now gone) I have a video of it I'll post and the pass side rear sensor is brand new (AC Delco)
    get a can of CRC Mass Airflow Sensor Cleaner from your auto parts store and spray clean your MAF sensor.... a dirty MAF sensor could be causing it as well....
    06MonteSS
  1. 95 Yukon - Weird Coolant Temp Sensor (to ECM) Issue
    By italie in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 05-11-2013, 07:59 PM
  2. What do these O2 sensor readings mean?
    By fulltimer in forum General Chevy & GM Tech Questions
    Last Post: 09-28-2011, 10:23 PM
  3. Compression readings....
    By bigbluesub in forum GM Powertrain
    Last Post: 09-02-2010, 10:59 PM
  4. rough idle/vacuum readings
    By dsfloyd in forum GM Powertrain
    Last Post: 08-30-2010, 03:51 PM
  5. question about tire size and speedometer readings
    By CMS in forum General Chevy & GM Tech Questions
    Last Post: 08-15-2010, 02:28 PM
