Results 1 to 2 of 2
    Default 1996" Chevy 1500 4wd Transmission Replacement
    Hello, I recently replaced my 4l60e transmission. I had one friend help take it out and another help put it in. We got the new transmission installed and the starter will not turn over. There is power to the larger wire on the starter but not the other wire. On friend said he took off a single wire screwed some where on the transmission. when putting the transmission back it I didn't notice a loose wire. Is there a ground wire on the transmission that would cause this? Thanks for any input. Drew
    ****Thread Moved****
    To The
    GM Powertrain Tech
    In this Tech Section, You should receive a High Count of Reply's and/or Advice.
  1. 1996 1500 Transmission Issue
    By Chevette in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-26-2011, 04:39 PM
  2. Ower of a 1996 Chevy S10 2wd 4cyl 5sp manual transmission.
    By spirittoo in forum Member Introductions
    Last Post: 08-29-2011, 09:56 AM
    Last Post: 11-24-2009, 02:20 PM
  4. 1996 Suburban 1500 4x4 Transmission type
    By barryT in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-09-2008, 05:23 AM
