    Default Fuel pump pressure sensor harness
    Hi Guys, I am new here. I have been cruising through peoples posts looking for answers. I was hoping somebody could help me. I have a 99 gmc sierra 1500 4wd. What i thought was the sending unit of the fuel pump that had gone bad turned out to be some critter had chewed through the wires of the fuel pump harness and the pressure sensor harness. I have the fuel pump harness but I can not find the pressure sensor harness( if that's what it is called). The fuel pump that I have is the Airtex E3500M model. Any help tracking down this part would be greatly appreciated.
    You could try a junkyard/dismantler. Get the part number from the dealer then google search that part specifically. Check gmpartsclub.com (site vendor)
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    if you are just talking about the plug or connector that goes to the fuel pump/sending unit, they are usually available at any parts store. If you want the entire harness then it is probably a dealer only part. As @dsfloyd suggested I would check a junk yard or get the part number and start searching online.
    Thanks guys for your reply so I found the part, it was the fuel tank pressure sensor lead connector. Had to get it from GM dealer. Hooked it up and the truck won't start now. It turns over but doesn't fire up. Which is weird to me because the truck ran fine and had no problems before. I turn the key to the on position and it shows that I have 3/4 tank. Wiring has to be correct if it now shows that( I assume). I changed the relay switch and the fuel filter. Any ideas?
    Jun 2013
    Fuel pump pressure sensor plays important role to measure manifold intake pressure,atmospheric pressure,vapour pressure in the fuel tank.Acc.to my view manifold absolute pressure sensor is best for sensing pressure & easy to use.it has silicon chip which is flexes when pressure changes.MAP sensor is directly located on manifold intake.Intake manifold pressure indicate quantity of fuel injected,time of ignition of cylinder & other function etc.
  1. fuel pump pressure
    By Jim Beard in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-02-2012, 06:04 PM
  2. Low Voltage at fuel pump harness
    By alchemist1 in forum GM Electrical Tech
    Last Post: 11-16-2011, 07:46 AM
  3. New fuel pump and still low pressure
    By J Young in forum Performance & Fuel
    Last Post: 09-25-2011, 11:36 PM
  4. 1993 k1500 4.3 fuel pump wire harness serial number question
    By lvrider in forum Chevy C/K Truck Forum
    Last Post: 11-07-2010, 07:06 PM
  5. Wiring harness to fuel pump
    By spaceball04 in forum GM Electrical Tech
    Last Post: 06-20-2010, 06:53 AM
