    Jun 2006
    Default NITROUS OXIDE -primer on Why-How it BOOSTS performance
    I'm not an expert in actual N20- nitrous oxide injection-systems -which is best best bang for buck-etc
    But I am familiar with the How/Why it works
    And it works GREAT-bang for ## performance-kits as little as $600 last i checked
    chemistry-quick HS chemistry review
    N20 is a compound-meaning it is composed of at least 2 different elements- Nitrogen and Oxygen
    N20 is also a Molecule -meaning when N and O combine-they actually SHARE their outer electrons
    electrons are tiny tiny-charged particles-when they move-you get electricity-Lotta power energy tied up in electrons moving arranging-all chemical electrical magnetic energy in fact.
    So N20
    has 2 NITROGEN atoms combined with 1 Oxygen atom
    How does it make power?
    SIMPLE- under higher temperatures easily reached in combustion chambers- it BREAKS APART and releases a VERY REACTIVE OXYGEN ATOM
    Simply inject it into the combustion chamber- WITH EXTRA FUEL!!! and it is like Pumping in more air- BUT BETTER
    No expensive turbo needed-clogging up intake and exhaust ALL THE TIME
    No expensive belt supercharger wasting energy plugging intake all the time
    So it is like a SUPERCHARGER-it adds more Oxygen-so you can BURN more fuel-make more power!!
    Upside
    1)Cheap $600 a few year back 2) simple to install for low power say 50hp boosts 3)Simple to remove 4)Only works WHEN you push button 5) Only hurts MPG when you hit button(factory gasoline turbos usually come from factory with low compression pistons- 8/1
    Downsides
    1) If too lean-you don't pump in enough gasoline-it will break your motor-too hot too much pressure-melt piston
    2) Even if enough fuel-it can break motor if motor not up to it-pistons crank -and timing concerns just like a turbo or supercharger
    3) Limited range-you have to refill bottle-not sure how many runs per bottle-few runs per bottle
    4)More HP requires more complicated install-dry systems mean you rely on your ECM to detect the extra Oxygen and adjust FI accordingly-but once you get to 75 extra hp or so-you might exceed what your FI system can easily handle-
    I think dry system means you rely on your EFI -wet system means you plumb in a separate fuel nozzle to spray in gasoline WITH the N20- wet more complicated more expensive-but probably safer-don't want to stint on fuel when running N2O RICH is good-lean is BAD
    History-
    Germans used N20 injection in fighters high altitude bombers recon planes in WW2-power at altitude where there is VERY LITTLE O2 in air
    Why not use LOX- liquid Oxygen-like a rocket or H2O2 Hydrogen Peroxide-like a rocket-
    BECAUSE TOO DANGEROUS TOO REACTIVE N20 is SAFE to handle- used in anesthesia-used in whipped cream bottles to make it fluff up
    and it also COOLS the intake charge-increasing power once again.
    Lotta poor kraut pilots DIED flying rocket planes at end of WW2-fuel was gasoline+ hydrogen peroxide- dangerous as heck
    Liquid "fuel" of shuttle-Oxidizing agent LOX dangerous
    N20 is best bang for $$-much better than headers CAI cam etc-requires some sort of ECM modifying chipping if you use higher power installs-say over 50hp "shots"
    Some of this might be wrong-in which case I stand corrected-
    Oh and a 50 hp shot is more or less the same amount of N20 no matter the vehicle motor because power produced is DIRECTLY PROPORTIONAL to O2 used per unit of time-meaning increase- if you use a certain amount of O2 per minute-you will produce a predictable amount of hp-no matter the engine
    Of course-not that simple-compression overlap burn efficiency all matter-but... in general double Oxygen in means double hp
    but the basic chemistry-is correct
    Which kit best-others will chime in-my suspicion- all name brands will deliver about as well.
    Well this is the general idea-adding N20 is just like adding more air-just BETTER CHEAPER COOLS MORE -
    Oh don't add boost at low RPMS harder on motor- bearings etc-your kit will tell you when to hit the button
    N20 is great-for under $1000 you can actually "feel" the torque HP increase- but no decrease in OEM drivability mpg throttle response NOISE when you DON'T want it.
    PS The krauts used methanol injection-and water injection-in their N2O systems to keep temps down-so wouldn't hole pistons with detonation-
    PPS Jegs sells a dry LSI kit for 98-2002 Firebirds for $632 75-100 hp-easy install
    barely double a CAI-but much much more power-bolt on-no change in noise of FE- except when you hit the button of course!!
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
    So N20
    Upside
    Downsides
    History-
    Good write-up! Thanks
    2010 GMC SIERRA CREW CAB (Silver) 4x4, ReadyLift 2.5" Level Kit, 305/60/18 Dick Cepek Mud Country, Go Rhino Nerf Bars, Husky Liners front and rear, Bushwacker Bed Rail Caps, SCT Programmer.
    Jun 2006
    Thanks
    If I wanted performance-N20 would be my #1 choice by a lot.
    CAIs headers exhaust systems-maybe $1000 for the 3 items-
    Lucky to get 25 hp-
    and it would be PEAK RPM HP-
    Now a 75 hp N2O shot-will give you 50-55 extra RWHP- double the CAI HEADERS EXHAUST SYSTEM
    and a good stock 5.3 could easily tolerate a 75 hp shot
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
    Supoorting mods work wonders tho. Without them your still limited...
  1. Nitrous goodness
    By nonnieselman in forum Performance & Fuel
    Last Post: 06-14-2013, 10:44 AM
  2. I'm new help with 89 5.7 hp boosts
    By bcoffman in forum GM Powertrain
    Last Post: 05-05-2009, 07:54 PM
  3. 1st gen bagged s10, what color primer you got?
    By scrapeincali in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 03-25-2009, 08:54 PM
  4. Help! paint or primer
    By ajkourafas in forum Photo & Video Gallery
    Last Post: 04-28-2008, 02:19 PM
  5. nitrous?
    By 07 redrado in forum GM Powertrain
    Last Post: 02-22-2008, 01:35 AM
