    Default Eletrical ground work
    I was thinking about adding a few more grounds to my truck. Is it just a matter of splicing and adding another connection or is it more complex than that?
    -K&N Air Filter
    not even splicing, just hooking up thicker wire to either the same locations or alternate locations
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    So basically cut the end, add a thicker gauge wire, then reattach? Thanks for the help
    Hello:
    First, what are you trying to modify? Do you want extra grounding for amplifiers in the cab? If so, you can ADD an extra, larger gauge ground cable by using a GM style side mount screw with an extension on the back to accommodate extra ring terminals, and you can (after crimp fitting ring terminals on both ends) run the cable from the ground to the rear of the truck by the area where the amplifiers are located, bolt it to the frame, and on the other side of that bolt (other side of the frame) hook another cable of same gauge up to the floor and bolt that to the floor with a bolt long enough to fasten your grounds from the amplifiers. Or drill a hole in the floor big enough for a Monster or other water proof grommet for a large gauge cable, and terminate the ground to a post or distribution block where you will place all your amplifier grounds.
    If you are trying to get a better ground for electrical system in general, the above to the frame will work, and/or you can remove the existing cable (terminal and all, don't cut it) and replace it with a larger gauge cable and terminate at the block like the old one, and put a second cable to the frame as well. You can buy your GM side mount terminals to crimp on the cable at NAPA. You need to buy a special crimp tool that is used with a large hammer, preferably on the anvil portion of your bench vise.
    I have the set up above on my truck. I am also going to replace the ground cable to the block. I am using 1/0 gauge cable for the block ground, and the other ground is either 4 or 2 gauge cable.
    I am also using the top posts for extra cables by using marine terminals on them.
    And other vehicles and toys.
    Here's the scoop. I had it load tested a few weeks back and they said my alt was bad, so i replaced it. I had it load tested because whenever I would used my accessories (wipes, blinker, brakes, etc), my volts would drop to around 9. When I would continue driving, it would only go to around 11. I have a new battery (6 months). I replaced Alt. and the battery cable going to the engine block and wire wheeled where it grounds out. I am thinking I have a/or many bad other grounds.
    I just want to improve the connections to the frame because it being a 94 and living all its life in Michigan, I would assume some/most are rusted.
    The original post
    http://www.gmtruckclub.com/forum/sho...ectrical-issue
    ... I should also do this...
    i over rev-ed my truck last week and the gauges freaked out. i would turn on the blinker, the light, the fan and the whole dash had a seizer.
    i turned on the cruise control and it didn't seem to know if it was coming or going.
    it took me resetting the computer to get it right again.
    so yeah... good grounds would help the ECU distribute voltage and absorb loads better....
  1. Help needed from the ground up!
    By vickilynne in forum Chevy Silverado Forum (GMC Sierra)
    Last: 06-16-2012, 04:20 PM
  2. Dumb Ground Hog
    By Pikey in forum The Coffee Shop ~ Chit Chat
    Last: 06-13-2012, 09:09 PM
  3. Elusive Ground?
    By PerusTC in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-22-2012, 03:18 PM
  4. ground affects
    By express conversion in forum Chevy Express Forum (GMC Savana)
    Last: 06-12-2011, 12:44 PM
  5. 1st snow has hit the ground!
    By Johnny_Buchanan in forum The Coffee Shop ~ Chit Chat
    Last: 10-16-2010, 10:18 AM
