    Default 2008 silverado leveling kit gas tank problems
    I have a 2008 chevy silverado z71 ltz crew cab. Recently put a 2.25 leveling kit on from skyjacker and nitto terra 285/70/17 on. I am having problems with running out of fuel. Truck will say 74 miles to empty and then just shut off. Does anybody have any suggestion on what I could do. I am consisting taking the leveling kit off. Really really done want to.
    I know this doesn't help you, but when I had just the front leveling kit (2.5") on my '08, I never had this issue. Unless your sending unit is different, for some reason?
    -Sal
    Desert Brown Metallic
    Fuel pickup should be lowest part of the tank... seems strange a leveling kit would affect this. If you really think it is the level kit you have an option to install blocks to the rear to put a little rake back in.
    Former Member
    Apr 2012
    Reading, PA
    I would suspect a faulty pickup/sending unit in the tank (not completely on the bottom of the tank) or the calibration is off. Going up a slight incline without a leveling kit would have caused the same issue...so its not the leveling kit.
    Quote Originally Posted by Bueghly View Post
    the operating of this vehicle with less than or at 1/4 amount of fuel is not recommended. the fuel pump requires fuel to be cooled. overheating will damage the fuel pump. if the front end was made higher than rear by even a small amount the fuel tank pump will not be able to suck up the fuel from the front of the tank when at a low level. keep fuel at 1/3 or more at all times.
  1. 2008 4.8l chevy silverado towing problems
    By outdoorsboy87 in forum Chevy Truck Talk & GM News
    Last: 07-11-2013, 09:31 PM
  2. 1977 K10 fuel gauge/tank problems
    By prototype51 in forum General Chevy & GM Tech Questions
    Last: 05-27-2010, 11:41 PM
  3. 83 K20 fuel tank problems
    By SPCMarty in forum Chevy C/K Truck Forum
    Last: 01-16-2010, 07:06 AM
  4. 1989 chevy 1500 gas tank installation problems
    By poison0046 in forum General Chevy & GM Tech Questions
    Last: 11-30-2009, 02:00 PM
  5. How big is the fuel tank for 2008 Silverados?
    By JKEY817 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-10-2008, 03:59 PM
