    Default torque without a wrench
    I need to torque some hub bolts on a Toyota car to 70 lbs. I only have a breaker bar.No torque wrench.
    Can someone describe what 70 lbs will feel like with the bar??
    how long is the breaker bar??? if it is around 18 inches long, I would say almost no pressure is 70 lbs. Personally I would never torque any wheels less than 80 ft. lbs. myself. with a bar of that length any pressure you put on it will more than likely overtorque it.
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    You can get a 1/2" drive torque wrench from Harbor Freight for under $25 right now. Quite often they go down to $20. While it's not the best quality, it's fine for most work and worth the money.
    Christopher
    Jun 2013
    San Antonio, TX
    If you check on line, you can probably find some Harbour Freight coupons. There is usually a 20% coupon floating around out there.
    Mike
    2003 Suburban LT
    2WD, 5.3L Flex Fuel
