    Default Towing capacity 2500 HD - What is it?
    Hi Folks - I am new here but could use some help. I just bought a used 2012 Silverado 2500HD 6.0 liter / 6 speed auto tranny with 3.73 gears. I've been a camper for years and towed many RV's. Last truck was a Ford dually and could tow heavy loads but had too much trouble with the truck so we dumped it. Here is my question: How much can I tow with my 2500HD? The book says only 9500 lbs, other folks tell me the book is really under rated and you can town up to around 12K - is this true?? My fifth wheel weighs around 10500 dry weight and if loaded up to the max it could weigh 12K - I don't plan on loading it up to the max but is around 10-11K an OK weight? Anyone who can help would be great to hear from you
    Welcome to the club, it's great to have you aboard. I have a half ton but I tow what I want. I just hook to it and go, I know I have gone over the pulling capacity but it does it well. Good luck man.
    Welcome...... I have a 2013 2500 Hd also.... you should not have any problems towing your 5th. wheel. Especially being a camper.
    Proud Husband and Father.....
    Thanks for the reply - hope my heavy Chevy does the job. My fifth wheel weighs about 11K loaded so hope the truck can handle it
    Have a slightly older one,'07-std.cab,LB,4x4, 2500HD, manual trans., 4:10's. "the book" is interesting, 10,200 w/3:73's - 12,700 w/4:10's. If you "do the math", the difference in engine RPM between those two gear set's isn't really that much. Oversize tires might make that much difference. So i'm not sure why there is 1 1/4 tons difference in rated trailer wt ? I have towed up 14K- short distance, no traffic and 55 was max speed, I wasn't comfortable with that large of a load - didn't feel like me and the chevy were "in charge" ! I have towed close to 10K several times, you'll want to make sure all the brakes are good and the tire pressures right ( I'm probably preaching to the choir here ) The truck did fine . I don't think I would be "comfy" with much more on any trip where I had to fight traffic or many steep grades however. You won't like the fuel "economy", as there is no "fuel economy" w/ a fully loaded 6 litre. I don't even check mine loaded - I really don't want to know !! KEN
    Hook n Book my Friend just when ya find a hill make sure u find the skinny pedel ;)
    99 Gmc Sonoma SL 4.3L 4x4 Reg Cab Long Bed
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Welcome to the Club!!!
    ****Thread Moved Here****
    TIRES:
    BFG All Terrain KO 315/70/17
    Former Member
    Apr 2012
    Reading, PA
    Quote Originally Posted by Camper947 View Post
    ...9600#s with 3.73s, 13k#s with 4.10s...
    At that weight, you will be working pretty hard unless you're all flatlands...personally, if I liked the truck, intended on keeping it for a while, and already had that camper; I would find someone to swap me in some steeper gears (I would skip 4.10s and go with 4.56s)...
