Results 1 to 10 of 13
    Default service stabilitrak/service traction control on message board
    I have a 2011 silverado with 5.3L. I noticed these two messages flashing at me and I can't get them to turn off with manual reset instructions. Is the dealer my only option? Is there something I can fix?
    Tim
  2. Likes Steve liked this post
  3. #2
    Start by getting the codes read so you can determine whats going on, I wouldnt presume itll be something simple, they rarely are but theres always a chance.
    You should still be under warranty.
  4. #3
    How many miles on this? You said these are flashing messages, or is that just a figure of speech?
    Steve
    10 Chevy Traverse LT AWD
  5. #4
    It has 34K, messages alternate on the message board, traction control and ABS warning lights on the dash are on solid....
  6. #5
    Default Codes
    I've had the same warnings because of low battery voltage I do agree you should have it checked for codes
  7. #6
    I have had the issue twice in the past on my 08.
    The first was caused by a "tech" lifting the truck and catching a wheel sensor line pulling and damaging it. The lights were NOT on when I shut truck off at dealer, but were on when I started it to pick it up. Then the "tech" said, "they were on when I pulled it into shop...." Yeah, uh I was there on full warranty, ya think I may have mentioned it??? I no longer use that dealer.
    The second time the symptoms were accompanied by a harsh 1st to 2nd shift. After much troubleshooting by my new dealer, who is awesome, it was found the wire bundle behing the brake assembly(power adjustable) was chafing and shorting. I believe there is a TSB on that issue.
    Charlie
    XS ive1:(^^^)
    2008 Silverado Crew LTZ Southern Comfort conversion
    SoCo cat back duals
    Volant CAI
    6" Pro-Comp lift
    ARE cap with Yakima rack system (winter)
    GM Hard tri-fold tonneau (summer)
    GM rear wheel liners
    XS ive2:(avatar)
    2014 Silverado 2500HD CCSB LTZ Z71 6.6 DMax/Allison
    6.5" BDS 35" Nitto Trail Grapplers
    LineX/wheel liners/OEM tube steps/sunroof/slider/mirrors/Nav/cablights/trifold tonneau
    Getting the toys to the track with a 2007 Roadmaster 7X12 V-Nose 7k tandem "Mobile Man Cave".
  8. #7
    Apr 2011
    Thornton, Colorado, United States
    XS ive,
    Do you have any idea what the TSB number is on the chafing harness? I have similar symptoms on my '07 Suburban. The Stabilitrak light comes on when coasting, like when coming up to a stoplight. It usually clears within a minute or so, but if I start out while it's still on, then the shift to second is very hard.
    Alan
    2010 GMC Sierra SLT
    2007 Chevy Suburban LTZ 4WD, aka BB
  9. #8
    Quote Originally Posted by Tim Kreps View Post
    Tim
    Mental note for me.*check year model of vehicle*-Check
    *has wheel cylinders*-check..
    *issue is something with that year model*-check.....
    Okay I'm good to ask a question on brakes now!! Hahaha (only a few will get this if they read it)
    Anyway, have you recently had your brakes serviced for repaired for any reason?
    I read below that they stay on solid. Have they always stayed on solid or did they come on and go off under throttle or braking?
    2009 Silvia~Superlift 6"~DropStars~Nitto Trail Graps~FSOR Catback~Madtunes Racing~4.10 gears~cleared headlights~hi-6
    NNBS SILVERADO BUILD
  10. #9
    Quote Originally Posted by Alan Crosby View Post
    XS ive,
    it was bulletin 08-07-30-021F
    Charlie
    XS ive1:(^^^)
    SoCo cat back duals
    Volant CAI
    6" Pro-Comp lift
    XS ive2:(avatar)
  11. Thanks Alan Crosby thanked for this post
  12. #10
    I think you have a problem with the throttle position sensors on the throttle body (it's actually the motor that operates the butterfly). GM has extended the warranty to 10 years. I had mine changed last month. works fine.
    Read this thread, it has the TSB number in it. http://www.gmtruckclub.com/forum/sho...ce+Stabilitrak
