    Aug 2011
    North Carolina
    Default What to do next? Lights?
    Hi everyone! Trying to figure out what I want to do next to my truck. HID? or change the bulbs in my tail lights? Or something else for <$100? Just looking to add a little bit at a time. Do not have the money to completely change headlights and tail lights and 3rd brake light and all that right now. Again, looking to add just a little extra. Any thoughts? Much appreciated! BTW pics of my truck on on my profile.
    Quote Originally Posted by Rocket32 View Post
    I have read that if you should not put HID bulbs in the stock housing as the reflectors are not made for HID light.
    Since you put on chrome door handles, maybe you could put on a chrome tailgate handle (I did it to my 2013). You can get the chrome stick on handle off ebay for less than $20. From your pics, I assume you have an LS (chrome steel wheels), so here is an ebay listing for a chrome tailgate handle.
    http://www.ebay.com/itm/07-12-Chevy-...c68b6c&vxp=mtr
    Also look at putting on chrome mirror caps.
    http://www.ebay.com/itm/Silverado-Ta...ffeac5&vxp=mtr
    If my assumption is right, I would also suggest getting a tailgate lock. In some areas tailgate theft is a big problem. You can get this unit from BOLT, it has a smart tumbler that learns your factory key. If you decide to get it, you will need to get a chrome handle with a key hole.
    http://www.autoanything.com/hitch-be...FcN_QgodYncATQ
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    Amber bulbs in the DRL cost about $4 for a set, and look good, I think.
    Aug 2011
    North Carolina
    I appreciate the feedback so far! I am taking everything into consideration so all you guys' opinions help! Thanks.
    Also, pretty sure I want to do something with lighting. Is changing the interior lights and license plate lights to LED's difficult and costly? Thanks!
    Quote Originally Posted by buckmeister2 View Post
    From his profile, he has a 2008 Silverado. They use the low beam for the DRL whereas the NBS Silverados had a separate DRL bulb.
    Adding to what others have said... custom front plate, bug guard, decals etc. There's allot that can be done at $100 a time.
    if you end up doing your headlights, save yourself alot of time and money and DO NOT do it little by little, do it all at once and do it right the first time... do a proper HID retrofit
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    I have had my HIDs for 5 years in stock housings with no problems. If you buy a quality light kit and use a relay to protect the factory electrics it should be good.
    01' 1500 LT Z71 ECSB 5.3L
