    Jun 2013
    Calgary, Alberta, Canada
    Default Intake manifold re-seal 4.3L
    Hi everyone. My 2000 Chev 1500 4.3L V6 RWD has a coolant leak at the front of the intake manifold. Is it better to get the whole seal kit that includes valve cover gaskets and everything else or just the upper set which will only do the manifold. I'm asking because the whole kit is double the cost. I will be doing the repair myself. Oh, and if anyone has any tech tips for this job let me know. And yes the 4.3 does have coolant flowing through it. soon enough I will upgrade to a V8, but not yet. Thanks for any and all your help.
    is it the upper intake gasket or the lower?
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    Jun 2013
    It is the lower gasket. I think I have decided to buy the whole seal kit. It's probably best to change all the gaskets and o-rings while I have it apart. Spending the extra money will mean base model shocks. Oh well, at least I'll have peace of mind in it's reliability.
    if your doing all the work, thats not a bad idea at all, good luck
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
