Results 1 to 10 of 45
    Jr. Engineer Cowpie's Avatar
    Jun 2013
    Central Iowa
    Default PCV oil catch can/separtor
    Well, just got done putting on a Jeg's PCV oil "catch can" separator on my 2013 5.3L. Real easy project. Had it done in 20 minutes.
    http://www.jegs.com/i/JEGS+Performan...52205/10002/-1
    with this separator one end goes to the pcv and the other to the throttle body ? any oil getting by the pcv is captured in the separator and is not sent to the / thru the throttle body.
    with this being a new vehicle did the separator catch any oil ?
    Jun 2013
    Central Iowa
    You got it. This filter goes between the PCV outlet in the driver's side valve cover and the intake manifold. On the 5.3L in the Silverado, the inlet to the manifold is on the very top and not thru the throttle body like on some of the cars. Just put it on last night, so too soon to see any results.
    Will see how much is getting caught by this system. Whether the vehicle is old or new, oil in some measure always gets transported right along with the gasses that are drawn up thru the PCV. Will post pics at various intervals showing how much is being caught. I am cognizant of the fact that this particular brand of setup may not do as well as I hoped. I am looking at a couple of other units if this one does not do well. There are several folks on other forums that have had excellent results from this one, so I decided to give it a try.
    Decided to go out and take a pic. Put about 130 miles on the pickup since last night. Here is the oil the filter took out of the PCV system just in 130 miles......
    Is nice.
    I like.
    The Cheap-*ss Modder & Thread Killer
    The Realist says, "The glass is too big".
    2013 GMC Sierra 1500 SLT Z60 4WD Crew Cab
    Mineral Green Metallic w/ Tan Leather Interior
    5.3 L FLEX w/AFM, 6A, Cheap-*ss Mods
    32 Dump Club Member
    Range V8 AFM Eliminator
    I have to say that this thing looks just like my craftsman water separator for my air compressor. Just a different label
    Jun 2013
    Central Iowa
    Yeah, I would agree! Does look a little cheesy. But I wanted to try something to see how much of this whole PCV oil thing was realistic or just a bunch of hooey. I am solidly convinced that this is a problem. I will be moving up to one of the top notch catch cans soon. Though the Jegs unit looks like a relabeled compressor unit, it sure has separated out a LOT of oil already. Better than nothing, I suppose, but I am moving up to something better, more than likely, the RevXtreme can.
    Since they got brought up a few posts back, I would sure like to see the internals of the Moroso cans to see how they are doing their thing. Anyone got any pics to share?
    Cowpie -
    Thanks for the info, it will be handy for me when I get around to doing this. Should the intake manifold be cleaned after install a kit? If so any recommendations? My truck has 48,300 or so miles on it. So I'm thinking there could be some real build up of crud.
    Jun 2013
    Central Iowa
    That might be a good idea. I would seriously consider a seafoam treatment thru the throttle body and into the intake manifold. Maybe others can chime in and offer something better.
    Just a thought for folks thinking of doing this, and wondering which unit is "best". If you are familiar with the "point of diminishing returns", it may never apply better than here. The Jegs unit, or a good quality air compressor oil separator, are about the same item. For our standard-or-slightly improved performance Silverado engines, they will remove at least 80% of the oil that the $180 Moroso unit will remove. With that 80%, you will not "feel" any improvement in performance, though your engine will run slightly better,and certainly run cleaner. If you pay the additional $130 or so for the Moroso, you have exceeded the point of diminishing returns. Maybe it is important to have "the best" at all times, and that is great. But, if that is not terribly important, and you are like many of us who do not have extra money to spend, you are not getting any bang for your buck by buying the best oil separator/catch can available.
    Master Mechanic
    KyleZ71's Avatar
    Jun 2010
    York and Wilkes Barre, PA
    Quote Originally Posted by buckmeister2 View Post
    I liked the way the Moroso mounted, was clean looking, and was a larger unit. Sorry if it wasn't the best bang for the buck
    Objects in mirror are losing
