    Default Removing marker from painted pannels
    I picked up a few painted parts from the autowreckers and they have written on them with some type of paint marker. Anyone know the best way to get it off without damaging the paint underneath it?
    Rhys - Canada
    2002 GMC Sierra SLE Z71
    1969 Chevy Impala Sport Coupe
    I would try googone or even maybe some gasoline on a rag.. they shouldnt strip the clear off but it will remove any wax ect.
    Sr. Engineer Dana W's Avatar
    Dec 2011
    Chuluota, Florida
    A very high grit number polishing compound will get it off. It can't be stuck on very tight. i have removed spray can vandal graffiti with scratch doctor.
    Elbow Grease. Get a good cleaner, and scrub away. googone works pretty good.
    2012 Chevy Captiva Sport LT V6 (The Spanish Prison)
    MODS:
    Cobra 19 Ultra II CB and some generic CB antenna.
    55W 10000K HID High Beams (just to remind the wonderful citizens of Hampton that their High Beams are on)
    Upcoming mods:
    [_] Exhaust [_]Subwoofers [_]More HID's [_]LED's [_]MORE LIGHTS!!! [_]Carr Light Bar w/ 3 or 4 in round off-road lights. [_]Black out Badges [_]Black out exhaust tips [_]Black out imitation skid plates on front and rear [_]Hopefully find a way to keep fogs, low beams, and high beams on at the same time
    Jason
    if they are metal body panels a clay bar might take it off without causing any damage.
    Clay bar or metal polish will do. With of course a lot of elbow grease.
    Get an eraser wheel. Try easy off oven cleaner.
    I like all dogs I meet, and some people too.
    Jr. Engineer Jamm3r's Avatar
    Dec 2012
    Minneapolis area
    The paint markers are low tech and easy to remove. The trick is to avoid removing the paint.
    I would use, one at a time, in sequence, until finding one that works:
    1) denatured alcohol
    2) xylene (or goof off, which is mostly xylene)
    3) a good nonchlorinated brake cleaner
    following label precautions
    The brake cleaner is likely to damage the clearcoat so you want to expose the paint to it as little as possible, and you may have to touch up the clearcoat afterwards.
