Results 1 to 9 of 9
    Default Transmission Fluid Change
    How hard is it to change the trans fluid on a Silverado 2005 Z71 or is it better to have it done at a privet shop?
    What i would do is...
    1.Drain fluid
    2.Drop pan
    3.Change filter with the proper new one
    4.Install pan with new gasket/gasket maker(Install plug)
    5.Fill with new fluid to proper level(check GM specs)
    6.Then pat yourself on the back and crack a cold one(or a couple)!BOOM!
    Line-X'd Bed
    5.3L Flex Fuel
    275/65R18 Toyo Open Country AT2's
    2" Rough Country Leveling Kit(want to get the 2.5 RC kit)
    EGR In-Channel Vent Visors
    Exterior PLUS Package
    Interior PLUS Package
    K&N Drop-In Air Filter
    ProFlaps
    Cat-Back Dual Exhaust
    Black Bowties
    ProFlaps
    Towing Mirrors
    Next Planned Mods
    Blacked out Tail Lights
    Aftermarket Rims
    Thanks Chevy :Drain the fluid, years ago you would drop the pan, and the fluid would run out as you took out the bolts, is that it? Also, the last time I had mine changed on a explorer they changed it threw the tubes in front of the motor, 70.00 dollars. Is one way better than the other?
    Dec 2007
    Lincoln Nebraska
    Quote Originally Posted by ChevyBoy2009 View Post
    1.Drain fluid
    2.Drop pan
    This is exactly what I would do also.
    2014 Silverado
    Bob.
    Thanks guys: I was wondering about the fluid in the torq converter, not enough to worry about? And ten four on the Beer.
    There are different theories on a trans flush rather than a fluid and filter change. If you change the filter and fluid by dropping the pan you do not get the fluid out of the torq converter. A flush leaves your dirty filter in, but changes the fluid in the torq converter. But, I have heard people say that a flush can make particles or dirt move from the place that they are sitting now and not doing harm to a place that they can do harm. I personally prefer the drop the pan method. It has worked for years without an issue.
    Dec 2007
    Lincoln Nebraska
    In my opinion, the fluid not changed in the converter is less likely to cause problems than the stuff stirred up with a flush, unless you have brown burnt smelling fluid, then that's a whole new ball game.
    Jun 2013
    Northern Illinois
    I have an '04 Sierra 2500 Hd with 186k and am going to use the Amsoil transmission flush before I switch over to there transmission fluid and was wondering about the fluid left in the converter if it will affect the performance of the new stuff because of the crap that the flush fluid breaks free. I would just be pouring it into the tranny not using an actual flushing machine. Any thoughts or suggestions on that?
    Master Mason E.F.W. Ellis Lodge #633 Rockford, Il A.F.&A.M. Independent Amsoil Dealer
    '04 GMC Sierra 2500 HD Ext. Cab WT
    Apr 2013
    East Central Iowa
    What I do in my shop is recommend both. Trans. service w/flush.
