Results 1 to 9 of 9
    Default Park or nuetral?
    1994 Z-71 4x4 auto.What is the best way to check trans fluid Park or neutral? Thanks
    P or N is the same as far as the internals of the tranny are concerned; but for safety, use P, the truck won't roll over the person checking the fluid level.
    Thanks RayVoy.Have a good one.
    Quote Originally Posted by RangerJ View Post
    Have a good one.
    Thanks, I was being a little sarcastic, but it was intended to be in good fun.
    While your checking fluids, check the two diffs and the t-case. Probably won't hurt to change the diff and t-case fluids while your at it.
    No offense taken.LOL how do,I check t-case?
    The fluid should be just below the bottom of the full plug hole (level ground)
    If you want to change the fluid, try a search where Conlan Rose was asking about fluid types.
    Here is one:
    Oh, BTW, be sure you can remove the fill plug before you remove the drain plug.
    Thanks for the info again.
    the most important step is make sure the fluid is at normal operating temp , having driven it for about a half hour or so of normal driving. then make sure your on level ground. try to park in the same spot to re-check the fluid. next is never over fill or you will create air bubbles and that will cause rapid tranny failure.
    I would use the up dated dexron VI fluid not dexron III.
    if the stick has gray on it drop pan and replace filter/fluid.
    Thanks J cat,
