    Default electrical issue not starter, alternator or battery?? 2004 Chevy Suburban 5.3L
    I have a 2004 Chevy Suburban K1500 5.3L non flex and some mornings the battery is dead. Nothing is left on that would seem to drain the battery, ie. lights or plug ins. I have had the battery tested and the starter as well as having the alternator replaced when it did not need to be. Had it bench tested after being removed and it was fine. Still their is some kind of a drain on the electrical system that I can't figure out. Any suggestions or advice??
    The only way to find it, is to insert an amp meter in series with one of the battery cables, note the current reading and start removing fuses. One at a time (replacing each one after it is removed) until the circuit drawing the current is identified.
    If you have a truck with the auto HVAC, check the blower fuses first.
    Jr. Mechanic blackburb's Avatar
    Nov 2008
    In Da U.P. of MI - - M Go Blue!
    Exactly what I was going to say. That's the only way to find for sure what circuit has the draw.
    '01 K2500 496 big block It's here! It's here! It's finally here!
