Thread: Fuel Tank Size
    Default Fuel Tank Size
    Trying to order a new fuel pump for the Burb but I cannot determine the fuel tank size using the RPO codes.Any advice?
    LMC has a section in their catalog for tanks.
    look up your year and trim
    Also if you have your owner's manual it should be in there.
    2002 Chevy Silverado & 1995 Ford Bronco
    02 Silverado: 50K miles, 20" Motto Rims, Flowmaster 50 Series
    95 Bronco: 160K miles, 4" Superlift, 33/12.5/15 Mickey Thompson
    01 Civic: 75K miles, DD
    -Erik
    call the dealership with vin# and they should be able to tell you.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Thanks,none of the RPO codes match up with the tank sizes. The choices when ordering a fuel pump for a 91 v2500 are 31 gal. and 40 gal. I would think the default on a heavy duty rig would be the 40 gal but I want to be sure. Owners manual only mentions that there are two different sizes. Did confirm I had the 4L80E tranny. That made my day.
    Used the measurements from LMC. 35x28x13. Its a 40 gal. tank.Thanks for your help.
    I suspect the 31 gal tank is "standard" and the 40 gal is an optional tank. If so, there should be an RPO code on the glove box sticker (if the 40 gal was installed at the factory). The RPO for a 40 gal tank is: NE2
