View Poll Results: What is your prefered tailpipe look?
Voters
46. You may not vote on this poll
  • Stock/Single rear pipe
    5 10.87%
  • Side pipes - out the side before the rear axle
    5 10.87%
  • Dual straight pipes out the rear
    16 34.78%
  • Dual angled pipes out the rear
    13 28.26%
  • None - tailpipe delete
    3 6.52%
  • Other - explain
    4 8.70%
Results 11 to 20 of 25
    Master Mechanic
    KyleZ71's Avatar
    Jun 2010
    York and Wilkes Barre, PA
    Quote Originally Posted by adampaul1964 View Post
    Good timing for this question, I just changed mine from straight out the back to side exit before the rear tire! No real preference either way, just wanted to change it up.
    Did you do both pipes out of one side or a pipe out each side before the tires??
    Objects in mirror are losing
    Quote Originally Posted by KyleZ71 View Post
    It's the Gibson Supertruck system, single in dual out, both pipes exit on the passenger side.My original system (straight out the back) rusted through and Gibson were good enough to give me a warranty upgrade to full stainless. I posted about it in my "truck changes" thread.
    http://www.gmtruckclub.com/forum/sho...-changes/page5
    Adam
    On my 2008 Silverado I had a catback dual exhaust with slash cut chrome exhaust tips coming straight out of the back under the bumper.
    My 2013 has the side exhaust exit with the bowtie emblem chrome exhaust tip.
    I perfer the first, but the second looks good too.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    Master Mechanic Burden33's Avatar
    Mar 2009
    Goose bay, Labrador Canada
    i had d/o the rear and i liked it until the exhaust moved and made it look like one side drop. I prefer to run either turn downs after the axel or before the axel depending on what i use the vechial for and i think it looks cleaner
    Fabtech/Banks Ram Air |Fuel Off Road/ 315/70/17 duratracs |Hyper tech / Spencershids |
    Color Matched Bowtie |15% Tint on Front Windows|20% Tint on Back Windows
    Chevy Ridin' High
    I love the factory exhaust because of its corrosion resistance and it still looks great. I will likely keep the factory set up until I replace my cats that are close to dead, but need to find a stainless exhaust that will last like the factory one. The exhaust is duel out of the engine until the muffler then its single.
    For me it depends on the vehicle. On my yukon xl I like the factory exit. Chances are if I ever do exhaust on it I will just duplicate the duel in duel out muffler and tail pipe setup. That is of course unless I come into some unexpected cash and do a Corsa system. Even then I would do the behind the passenger rear tire exit like oem. On my 95 I had them straight out of the rear with chrome tips on each side of the hitch.
    I really think it depends on the vehicle and its intended use.
    "The sheep pretend the wolf will never come, but the sheepdog lives for that day."-- Lt Col. D.Grossman. On Combat
  8. #18
    I prefer my exhaust to exit out the side in front of the rear tires.
    Chuckie!!!
  9. #19
    I like the dual tailpipes. The most impressive one I've seen so far are the 2013 Cadillac Escalade ESV Platinum trim.
  10. #20
    Im a Dual straight out the rear myself. Tips are fine but one of my pet peeves is MAKE SURE THEY ARE EVENLY MOUNTED!!! I dont know how many times I see one a little closer to center or one is dropped lower than the other. Kinda drives me nuts..should be a rule IMO. I also realize that getting the mounting perfect can sometimes be a PITA.
