GM Truck Club
Page 1 of 2 12 Last Post byLast Post by
Results 1 to 10 of 13
    Jr. Apprentice
    Jun 2013
    North Carolina ATM
    Default What size tires? Post 2-inch lift on Suburban.
    Right now I have a 2 inch lift on my suburban but my tires look tiny on it! I have 285/75/16's on it. I want a little bit wider and taller as well...what would yall suggest? I was thinking just 295's but not sure leaving the 75 or going up....not an expert on this lol...thing needs new tires all the way around either way so trying to figure out what to get.
    Quote Originally Posted by AnCap View Post
    I highly doubt you'll visually see a difference between 285/75/16 to 295/75/16. The 295 will only be 0.6" taller overall. Going to a 305/75/16 will give you a 1.2" height difference, which will be more noticeable.
    2013 Silverado LTZ White Diamond Crew Cab
    Mods:
    Advent OGM1 Navigation
    Husky Liners GearBox Underseat Storage
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Hypertech Max Energy Tune (only top end limiter removed and AFM disabled)
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    WeatherTech Front and Rear Splash Guards
    Husky Liners X-Act Contour Floor Liners
    WeatherTech Side Window Deflectors
    Jr. Apprentice
    Jun 2013
    North Carolina ATM
    Quote Originally Posted by stchman View Post
    What would going with the 85 do? I know the 275 to 305 would make it taller what about wider? I want it about a inch wider as well.
    Problem is that 85 aspect ratio tires look dumb (too much sidewall). 315/75/16 would be 1.77" taller and 1.18" wider. If you do go with a taller tire, make sure to re-program your ECU with the new tire height.
    Here is a good site for tire sizes.
    http://www.tacomaworld.com/forum/tirecalc.php
  5. #5
    Jr. Apprentice
    Jun 2013
    North Carolina ATM
    What would you suggest for 1-2 taller and 1-2 wider...it seems the back tires don't stick out as much as the front ones even though they are all the same size. It looks like a big body builder with skinny legs...lol..
    - - - Updated - - -
    Obviously I am no mechanic here but I saw a pic of a truck with 265/75/16's on it and they were wider than my tires...is the lower the number the wider the tire or is it reverse of that?
  6. #6
    - - - Updated - - -
    265/75/16 are not wider than 285/75/16
    The first number is the tire width in millimeters from sidewall to sidewall.
    The second number is the aspect ratio of height/width (a 75 is 75% of the tire's width is the sidewall height) i.e. 285 * 0.75 = 213.75
    The third is obviously the rim diameter.
  7. #7
    - - - Updated - - -
    Go to this website:
    http://www.tacomaworld.com/forum/tirecalc.php?tires=295-75r16-305-70r16
    You will find a interactive tire size calculator there. Enter your existing tire size and the tires you're thinking about changing to.
    See The USA In A Chevrolet,
    Or Buy A Ford And Stay At Home!!
  8. #8
    What year suburban do you have? I was wanting to put bigger wheels and tires on my 04 burban. I was thinking 35's with 20 in rims..?
  9. #9
    Jr. Apprentice
    Jun 2013
    North Carolina ATM
    Quote Originally Posted by LaTechDawgs View Post
    I have a 1999.
    - - - Updated - - -
    What about a 325/75/16 also I had a yukon I have 33/12.5/15's on would those be cheaper/easier to find?
  10. #10
    Alot of the larger tires i have seen lately have both sizes on them somewhere. I had 33/12.5x17 on my burb at one point that cleared and handled awsome. Also with wider tires if you add a spacer to the rear so its the same width as the front it doesent follow rutts and dips in the road as bad.
