Results 1 to 9 of 9
    Default Mykks' install of the Autoloc tilt hood hinge kit
    Hey everyone,
    I thought I would post up the most recent modification to my 2004 Silvy. Installing a Autoloc tilt hood hinge kit. Or as I call it, the Suicide Hood. (cause it sounds cooler)
    I am finding myself at more shows & cruise ins, and I wanted to do something to seperate myself from the crowd. And here it is...
    The Autoloc kit: part # tilthd
    Step one: Find where you're going to mount the brackets. I, obviously, needed them to be on the radiator support. I intended to weld the brackets to the support until I found out the rad support is aluminum and the brackets are powder coated steel.
    Step 2, Mock up:
    Remeber the old rule, measure a million times to cut once, this project is no exception.
    A mock up of how the whole hinge assembly will sit.
    This is when I discovered a hood clearance issue with the location of the heim joints. So I needed to flip the brackets around to move the joints back an inch.
    Vortec 357ci Small Block Chevy: Big cam, high stall, long headers, rear gears. The typical formula.
    Step 3, making your mark:
    With the hood barely open, just enough to squeeze an arm in and mark the location of the brackets mounting pads on the hood. Removed the hood and made the commitment to drill holes into my freshly painted steel cowl hood.
    As you can see, I was lucky enough that two of the mounting pads lined up with a hood support brace. The rear two pads did not, so I made a bracket out of aluminum stock to connect the pads and mount in the center.
    Say good bye to the convientional way of opening the hood. This is the last time anyone will see it the way that GM intended.
    Step 4, improvise:
    To address the issue of the old hinge, you simply notch the hood mounting point and allow the shoulder of the old hinge bolt to be your catch.
    A few minor tweaks, a few alignment changes of the hinge bolts and everything moves smoothly. There is however one hitch, with my application you can now only open the hood so far before the hood hits the grill. I also employed a long screw driver as a hood prop.
    Now I know what your thinking, "It's going to be a major pain in the arse to do any work under the hood". But all in all, it's not as bad as it looks. I've already changed the plugs, changed the oil, torqued the header bolts and R&Red the cold air intake for a cleaning. Really, the hood does not get in the way. And if I do have any major work to do, or need to get up by the cooling fans, the hood comes completely off with two 3/8" bolts.
    The After pics:
    My friends want me to call it the "Silverette" cause of the corvette styled hood. I can't bring myself to do it, give me a LS7 and than we'll talk ;)
    Cheers ~Mykk
    That's an awesome mod and a sick truck!! Good job!!
    Matt
    Hallsville, TX
    2005 Silverado 1500 LS Crew Cab 5.3L 2WD
    K&N FIPK II
    Magnaflow Exhaust
    Hypertech Max Energy Programmer
    Suspension Leveling Kit
    Putco Element Window Visors
    Carriage Works Billet Grille
    TruXedo TruXport Tonneau Cover
    That looks awesome! I think you'd have a hard time changing the radiator tho
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
  1. 04 Silverado 1500 Hood Hinge Cover Replacements?
    By quarterhorse in forum General Chevy & GM Tech Questions
    Last: 04-09-2010, 12:55 PM
  2. HOOD HINGE chevrolet SILVERADO 1500 HD part auto NEW
    Last: 03-17-2010, 04:42 AM
  3. HOOD HINGE chevrolet SILVERADO 1500 07-08 part auto NEW
    Last: 02-01-2010, 03:00 AM
  4. HOOD HINGE chevrolet SILVERADO 1500 07-08 part auto NEW
    Last: 12-21-2009, 11:20 PM
  5. 99+ Silverado door hinge pin install?
    By mayo in forum Chevy Silverado Forum (GMC Sierra)
    Last: 06-05-2009, 04:20 PM
