GM Truck Club
View Poll Results: 4WD Lever or Pushbutton
Voters
16. You may not vote on this poll
  • Lever
    9 56.25%
  • Push-button
    6 37.50%
  • No preference
    1 6.25%
Page 1 of 3 123 Last Post byLast Post by
Results 1 to 10 of 26
    Default 4WD Activation: Lever or Push Button?
    Just a question to see what my fellow members think... Do you prefer the current push button 4WD activation or the "old school" shift levers like on the mid 90s and back trucks?
    I like the push button personally. I have one on my 97 k1500 just seems like it goes quicker and smoother.
    I prefer a shifter, theres nothing like moving moving the lever and feeling/hearing the clunk of locking it in.
    I actually converted the t case airshifter on my rockcrawler to lever actuated.
    And while were discussing this Id rather have manual locking hubs to, automated equipment seems to have to many finnicky and delicate switches and sensors.
    Never had manual hubs and manual t case fail to lock in, unless they were frozen, then a few seconds with a propane torch fixed that problem. Cant say it was as easy to field fix automated hubs and t cases.
  4. Likes Drake_korthos, zuki82 liked this post
  5. #4
    Sure do miss my lever from my '06! Somethin more satisfying engaging the 4WD that way with a reasuring "thunk".
    2010 GMC Sierra 1500 SLE Extended Cab Z71 4X4 5.3L Flex Fuel
    MagnaFlow single in duel out system
    Volant CAI & Ram Air Scoop with Power Core Filter
    Rhino Tuff Grip Spray in Bed liner
    Undercover Classic Tonneau
    Trail FX Bug "deflector"
    AVS Window Deflectors
    Black Powder Coated Nerf Bars
    RECON L.E.D. Interior, 3rd Cab light, Projector headlights, and Taillights
    ATX Crawl Wheels wrapped in BFGoodrich Rugged Terrain tires
    CalTrend Neoprene seat covers
    2" leveling kit from Max Trac
    Diablo Trinity with Diablew Tune
  6. #5
    Definitely prefer the floor levers on my '84 & '90 trucks along with the decent sized light in the instrument cluster showing that 4X4 is engaged. My '08 Silverado has a rotary dial with one little light the size of a pin head in the dial that is barely visible in the daylight.
  7. #6
    I'm going to go against the grain here. Up until I lost my last job, I had two GM Trucks from 2007. One was the classic with the lever activation (the work provided truck) and the other is my personal Silverado NBS with the "autotrac" 4WD option, the little twisty knob selector (which is now my work truck). I got to try them both out in the mud and snow etc.
    At first I hated the new knob, but when it snows out here, I found that I prefer it over the lever. I like the haste free approach. Now, if I were a serious off-road guy as opposed of a site construction supervisor, I can see the multiple benefits to the lever. As mentioned above there is far less to break being the most obvious.
    2007 Silverado 1500 NNBS - Work truck and daily driver
    2002 Malibu - The wife's car, for now. I smell a Suburban in my future
    1976 Stingray - NOW OVER 100,000 MILES!
  8. #7
    I like the manual shift as well, and btw, you can still get it in the WD trim level.
    Ray
    '09 Avalanche LTZ - Black
    '05 Envoy XL (sold)
  9. #8
    Another one against the grain here... but still in the middle like bornagainbiker55. I've had both up here, and when driving up i70 heading to the slopes the push-button is much more convenient, when everything works. Quite a few more components that could fail but for my DD I like the convenience factor. With that said... if I get a company car I wouldn't mind throwing a 5 or 6 speed manual shift as well as lever for the t-case
    Charles 02 z71 Cladded Avy
    Mods: eBay k&n Intake, highflow magnaflow cats & y pipe, 6" FabTech lift, 35" Pro Comps, Superchips #2715, SnugTop, 4.56's, MOOG front end
    Wishes: LQ4 + a beefed up 4L60E
  10. #9
    lever for sure, just cant trust electronics all the time when you need them most
    2000 Chevrolet Silverado
    Powertrain:
    4.3L V6, 4L60E, 2WD, Single Cab
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    Flowmaster 10-series exhaust (dumped)
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Speakers: Alpine SPR-60C 6.5" component set, 4X6 Infinity Kappas
    Subs: 2-12" Kicker CVT's
    Amps: Alpine-M1000 (subs), Alpine MRX-F65 (Speakers)
    Tires/Wheels:
    305/70R16 NITTO Terra Grapplers
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Front/Rear-Bilstein 5100 shocks
    Lighting:
    FRONT
    35W HID Low Beams
    RECON LED smoked roof cab lights
    REAR
    HELLA LED taillights and 3rd brakelight
    HELLA FF-75 Aux. Reverse Lamps
    RIGID dually D2, flush mount, wide beam
    Accessories:
    Hawk HPS Brake pads
    Russell braided steel brake lines
    Powerstop-red powdercoated brake calipers
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  11. #10
    4wd and manual trans shifters are my preference
    Chuckie!!!
