    Default Anybody have any ideas?
    My 05 awd is giving me problems,,
    I have this vibration noise up front,
    So far I've changed the pass side cvt , brakes rotors calipers up front,,
    U joints front and back changed fluid!
    The problem is still there, I took off my front driveshaft, and it didn't help,,
    My van will move now when it is in park though!!!
    The drivers side bearing is a couple years old maybe I should change that now ,, it feels like I'm just throwing money away though
    Thanks for any help you can provide
    I have heard of guys replacing the bearings in those front diffs every 75,000 miles. I have know guys with over 300,000 on them and they have never touched them. You might want to take a look at the front diff and the front wheel hubs
    Is there bearings in there also?
    I can hear it get louder as the suspension loads!!
    Ive heard the pinion bearings can be a problem which is one reason I steer clear of them for resale.
    Hmm moves while in park, sounds like the park locking pawl has a problem. I dont remember if that model can be accessed from below by dropping the trans pan.
    One dealer told me worse case scenario was 1500 I found another one that would diagnose it for a hundred dollars,,
    hard to take my van out of service!!!
    Oh well I'll keep you posted
    Turns out its the 2 year old bearing on the drivers side,
    At the last minute I told them to diagnose my engine light too,,
    so that cost 140 to diagnose, I can change the bearing myself, it turns out its a solenoid so I'm having them fix it,
    They wanted 850 to do everything, so I told them to fix the solenoid, so roughly I'll have 600 bucks into it,
    Kind of makes me mad I was gonna do the bearing this morning, but being two years old I didn't think it would be the cause!
