Results 1 to 6 of 6
    Newbie RadRacer is a glorious beacon of light
    Jun 2008
    Florida
    Default New guy with a few questions
    How's it goin guys? I'm new to the forum, but not to Chevys . Die hard Chevy fan and driver. Anyways, my mom owns an '01 Suburban 1500 and she's been having some problems with it. She says it's accelerating roughly, and seems to almost stall. I just assumed it was a fuel filter, because I doubted the pump would go out by now (not sure how many miles on it, but it's not too high). After some searching, I came up with it's either the pump or the crank position sensor. She's going to drive the truck to work (97 Silverado, sport-bed) and let me take a look at the 'Burban. What kind of pressure should I be looking for? On my Camaro, it was roughly 40 at idle, hitting 60 under WOT, but that's a 6 cylinder. I'd assumer the 5.3 would call for more gas, so a higher pressure, right? Any other suggestions?
    2001 Suburban 1500: Lowered, 18's, cold air intake, BullDog Tuner Mom's Ride
    1997 Silverado 1500: short bed, step side, tint Dad's Ride
    1997 Camaro Z-28: non-running LT1Their "Weekend Warrior"
    1997 Camaro 3.8L V6: too much to list :D My Ride
    1986 Camaro Z-28: non-running drag car The Race Car
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    My '98 fuel pressure runs at 60 psi KOEO and ~50 at idle. I would expect the '01 to be the same. So I wouldn't expect more pressure than your camaro (a little fluid mechanics and pump engineering on the side: operating pressure and volume capacity are different parameters. You don't need to increase the pressure to get more volume)
    I would suggest hooking up a scanner to see if there are any trouble codes or pending trouble codes to point things in the right direction.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
    Jun 2008
    Florida
    Quote Originally Posted by MrShorty View Post
    Yeah, I'm no fluid expert :P. Anyways, she decided to drive it to work today because it started to run fine again?!? She did say a code was thrown, and it's being scanned tonight when she gets home . I'll check the F/P too then. From what I've read, if it's the pump, no codes are generally thrown; I'm hoping it's just the CPS.
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    Try changing out the filter if you have not already and if it is still acting up, there is a TSB and recall on the 2001 Suburban 1500 w/5.3 fuel delivery system. That is what my wife drives and we had it in the dealership for a random misfire code (bad coil pack was found) and they informed us about the recall and installed a new fuel pump in it at the same time for free (even out of warranty) because of the recall.
    Darcy
    Washington State
  5. #5
    Jun 2008
    Florida
    Quote Originally Posted by dwill3015 View Post
    We replaced the filter a few weeks ago. I thought there was a recall; we took it to the dealer and they claimed to have done something about it, but we weren't having the problem then. I'm taking it to my uncle's shop tomorrow to have the code scanned and hopefully repaired
  6. #6
    Jun 2008
    Florida
    Fuel pump was bad. Had it replaced Thurs; no problems so far
Similar Threads
  1. header questions? and other exhaust intake and tune questions?
    By elkosp16 in forum Performance & Fuel
    Last Post: 07-19-2010, 05:56 AM
  2. First time towing questions.. Tire psi/Air-bag questions
    By beforeiforget761 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-16-2010, 08:39 PM
  3. 5.7 questions
    By GMCZ71 in forum General Chevy Tech Q&A
    Last Post: 03-01-2010, 07:55 PM
  4. new guy, a few questions
    By aisabell in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-22-2009, 07:39 AM
  5. New 97 with questions
    By GiS in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-22-2007, 12:41 AM
