I couldn't find any threads directly addressing aftermarket mass air flow sensors. I've seen them advertised, and they claim boosts in HP and MPG. Has anybody used one? What kind of improvements did it give? Is it worth the $300+?? The main goal of any performance upgrades I'm planning is to improve gas mileage, so if this really makes a difference, I will add it to my list![]()
Matt
Hallsville, TX
2005 Silverado 1500 LS Crew Cab 5.3L 2WD
K&N FIPK II
Magnaflow Exhaust
Hypertech Max Energy Programmer
Suspension Leveling Kit
Putco Element Window Visors
Carriage Works Billet Grille
TruXedo TruXport Tonneau Cover
I have done a number of these in the past on many different trucks and each one noticed a definate increase in performance. Gas mileage is unknown, but I know the performance is there.
I am seriously considering getting one for my truck as well, but finances are limited right now. Seems I have bought too many toys recently! Within the next few weeks I will have one and let you know what I found.
P.S. The ones that I have installed were the Granettelli (if that's how you spell it). Fit like a glove and worked like a charm.
Crunch
"My Other Ride is Your Girlfriend!"
2006 Silverado Regular Cab Short Bed
www.stylintrucks .com
put in your vehicle, and they are under the performance section
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
I recently put the Jet MAF on my truck. I noticed about 2-2.5 miles per gallon increase, but had also put the platinum plus 2 plugs, and the granatelli MPG plus stainless plug wires on at the same time, so I cant really tell you which made the biggest difference. I just know that I saw it go from 14.5 mpg to roughly 17mpg, for about 50/50 city/highway driving...
2007 Silverado LT Z71 4x4 Crew Cab
Dark Metallic Blue
Mods to come, just purchased on 10/31/09
Go Pack Go!
I was looking at this Granatelli MAF on Stylintrucks.com and it reads in the description that it does not work with Hypertech programmers. I was planning on getting a Hypertech Max E-Con eventually, so I started thinking that I couldn't get an aftermarket MAF. Then, what looks like the same Granatelli MAF on JCWhitney.com says that it works great with aftermarket chips or programmers. I was curious why two places would say completely opposite things. Would an aftermarket MAF work with a Hypertech programmer?
After I thought about that, I wondered if the Hypertech would basically do the same job as an aftermarket MAF by re-programming the computer to take advantage of my aftermarket intake. Thoughts on these??
Matt
Hallsville, TX
K&N FIPK II
Magnaflow Exhaust
I went with the JET MAF, due to the fact that they do advertise them working with my Hypertech programmer...
Dark Metallic Blue
Go Pack Go!
Forget the handheld tuner and get yourself a real tune that will make a difference. www.nelsonperformance.com the tune is $375 with FREE retunes for LIFE and they can do far more performance adding adjustments than a hand held ever will. Some guys use www.gowheatley.com his tunes are $275 (I think) but you will also pay for retunes.![]()
Chris S. The GoFastPadre I like to drive fast and I've got the speeding tickets to prove it. 00 Sierra Z71 ECSB K&N CAI Pacesetter Shorties (soon to be replaced with LT's) Magnaflow HFC's Flowmasters with True Duals and H-Pipe more mods to come
Bookmarks
