Results 11 to 12 of 12
    Yeah that's true. Didn't really think that through. Making the knock sensor change now. Pain in the asthma right now.
    Current:
    Future:
    Jr. Engineer
    Aug 2010
    eas' bum fuk, maine
    Quote Originally Posted by dedmon27 View Post
    Mine went about two years ago, but it was completely my fault. I was out of town for work for about two weeks. Knowing when I got back I had to change the oil and stuff. So when I returned and started to add the oil I noticed a nice mouse nest under the intake. So I took my pressure washer and sprayed the heck out of it. Needless to say about a day later Check Engine light on. Scanned and sure enough Knock sensor. So I replaced them both, yep under water. So I used silicone to seal the ports when I replaced the covers. Anyway anytime your check engine light (CEL) is on you lose fuel economy. After your vehicle reaches operating temps it goes into "closed loop" meaning the computer reads all the sensors and adjusts the way your engine runs. CEL on means your vehicle stays in "open loop" and runs off pre set perameters in the computer, hense lower MPG's.
    depends on what code sets or what sensor fails. if maf or o2 sensor (etc) fails then yes its stuck in open loop because it NEEDS those sensors to be in closed loop. if its just an evap code setting the light then close loop is still going to function.
    Quote Originally Posted by rileyjr16 View Post
    Well i now have some water dropping out of my exhaust pipes so... Gotta change those head gaskets anyway.
    good rule of thumb... for every gallon of gas burned, a gallon of water is produced.
